[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
    Mills, Richard Tran
    rtmills at anl.gov
    Mon Nov 26 18:22:25 CST 2018
Oh, I should also have asked: Why are you telling PETSc to not use mkl_sparse_optimize()? Does it cause some sort of problem if you build with that on?
--Richard
On 11/21/18 10:59 PM, Stefano Zampini wrote:
Richard,
I just noticed that PETSc master does not build with the options
    '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
    '--with-mkl_sparse_optimize=0',
This is on frog at MCS, but it will be the same on other machines as the macros configuration
PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
PETSC_HAVE_MKL_SPARSE_SP2M defined
does not seem to be supported.
/nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797): error: struct "<unnamed>" has no field "csrA"
    csrA = a->csrA;
Could you please take a look? Why is the mkl_sparse_sp2m package flagged as lookforbydefault in the configure scripts?
Thanks
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181127/8f2ff1cc/attachment.html>
