[petsc-dev] Mat updating from 3.7 to 3.9.2 Fortran
Smith, Barry F.
bsmith at mcs.anl.gov
Wed May 23 19:15:30 CDT 2018
Use -mat_view on the new and old code to verify that the same matrix is actually being generated.
Barry
> On May 23, 2018, at 6:18 PM, Hector E Barrios Molano <hectorb at utexas.edu> wrote:
> Thanks Jed for the Answer.
> I am still having problems with this code. In summary what I changed from PETSc 3.7 to 3.9 was:
> - use of PETSC_NULL_MAT to evaluate if the matrix was defined
> mat = PETSC_NULL_MAT
> if(mat .eq. PETSC_NULL_MAT)then
> create matrix,vectors, ksp
> else
> KSPSetInitialGuessNonzero
> VecResetArray
> end if
> - modified MatSetValuesBlocked call
> Previously it was:
> call MatSetValuesBlocked(mat,1,N-1,IROW,LC(nnz),BB(nnz),INSERT_VALUES,ierr)
> with N-1, LC(nnz), and BB(nnz) scalar values, the elements where inserted one at a time
> Modified to:
> call MatSetValuesBlocked(mat,1,[N-1],IROW,[LC(nnz)],[BB(nnz)],INSERT_VALUES,ierr)
> After the matrix is built there is a call to
> KSPSolve
> When I run the program I get a lot of these errors:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.2, unknown
> [0]PETSC ERROR: ../../../UTCOMPRS on a named bandera by hector Wed May 23 18:08:07 2018
> [0]PETSC ERROR: Configure options --prefix=/home/hector/installed/petsc_git-intel-debug --PETSC_DIR=/home/hector/dwnld_prog/petsc --PETSC_ARCH=linux-intel-debug --CC=mpiicc --FC=mpiifort --CXX=mpiicpc --with-openmp=1 --with-valgrind=1 --with-valgrind-dir=/home/hector/installed --with-parmetis-dir=/home/hector/installed/parmetis/ --with-metis-dir=/home/hector/installed/parmetis/ --with-zoltan-dir=/home/hector/installed/zoltan/ --with-hypre-dir=/home/hector/installed/hypre --download-ptscotch --with-blaslapack-lib="[/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_lp64.a,/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_core.a,/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_thread.a]" --with-scalapack-include=/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/include --with-scalapack-lib="[/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_scalapack_lp64.a,/home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a]" --with-shared-libraries=0 --FC_LINKER_FLAGS="-qopenmp -qopenmp-link static" --FFLAGS="-qopenmp -qopenmp-link static" --LIBS="-Wl,--start-group /home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_lp64.a /home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_core.a /home/hector/installed/intel/compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_thread.a -Wl,--end-group -liomp5 -ldl -lpthread -lm"
> [0]PETSC ERROR: #305869 MatILUFactorSymbolic_SeqBAIJ() line 369 in /home/hector/dwnld_prog/petsc/src/mat/impls/baij/seq/baijfact2.c
> [0]PETSC ERROR: #305870 MatILUFactorSymbolic() line 6522 in /home/hector/dwnld_prog/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #305871 PCSetUp_ILU() line 144 in /home/hector/dwnld_prog/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> [0]PETSC ERROR: #305872 PCSetUp() line 923 in /home/hector/dwnld_prog/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #305873 KSPSetUp() line 381 in /home/hector/dwnld_prog/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #305874 KSPSolve() line 612 in /home/hector/dwnld_prog/petsc/src/ksp/ksp/interface/itfunc.c
> What could be the problem?
> Thanks for your help,
> Hector
>> writes:
>>> Hi PETSc Experts!
>>> I am updating a Fortran code that use PETSc 3.7 to version 3.9.2 (from
>>> git repository).
>>> Such code declares:
>>> Mat mat
>>> and used it as an integer, for example, to assign an initial value and
>>> test it to know if the matrix has been created by PETSc.
>>> data mat/-1/
>>> if (mat .eq. -1) then
>> You can use PETSC_NULL_MAT
>>> With the new PETSc Fortran modules the compiler complains about this and
>>> stops.
>>> Is there a better way to achieve this? So that I do not have to set an
>>> predefined value to Mat type to test if it was already created by PETSc?
>>> If not, Is there a way to access the value in mat?
>>> Looking at the source code type(tMat) has "v" variable, so could I used
>>> as mat%v?
>> Please no.
