[petsc-dev] Mat updating from 3.7 to 3.9.2 Fortran
Matthew Knepley
knepley at gmail.com
Wed May 23 18:40:36 CDT 2018
On Wed, May 23, 2018 at 7:18 PM, Hector E Barrios Molano <hectorb at utexas.edu
> wrote:
> Thanks Jed for the Answer.
> I am still having problems with this code. In summary what I changed from
> PETSc 3.7 to 3.9 was:
> - use of PETSC_NULL_MAT to evaluate if the matrix was defined
> mat = PETSC_NULL_MAT
> if(mat .eq. PETSC_NULL_MAT)then
> create matrix,vectors, ksp
> else
> KSPSetInitialGuessNonzero
> VecResetArray
> end if
> - modified MatSetValuesBlocked call
> Previously it was:
> call MatSetValuesBlocked(mat,1,N-1,IROW,LC(nnz),BB(nnz),INSERT_
> VALUES,ierr)
> with N-1, LC(nnz), and BB(nnz) scalar values, the elements where inserted
> one at a time
> Modified to:
> call MatSetValuesBlocked(mat,1,[N-1],IROW,[LC(nnz)],[BB(nnz)],
> INSERT_VALUES,ierr)
> After the matrix is built there is a call to
> KSPSolve
> When I run the program I get a lot of these errors:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.2, unknown
> [0]PETSC ERROR: ../../../UTCOMPRS on a named bandera by hector Wed May 23
> 18:08:07 2018
> [0]PETSC ERROR: Configure options --prefix=/home/hector/
> installed/petsc_git-intel-debug --PETSC_DIR=/home/hector/dwnld_prog/petsc
> --PETSC_ARCH=linux-intel-debug --CC=mpiicc --FC=mpiifort --CXX=mpiicpc
> --with-openmp=1 --with-valgrind=1 --with-valgrind-dir=/home/hector/installed
> --with-parmetis-dir=/home/hector/installed/parmetis/
> --with-metis-dir=/home/hector/installed/parmetis/ --with-zoltan-dir=/home/hector/installed/zoltan/
> --with-hypre-dir=/home/hector/installed/hypre --download-ptscotch
> --with-blaslapack-lib="[/home/hector/installed/intel/
> compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/
> libmkl_intel_lp64.a,/home/hector/installed/intel/
> libmkl_core.a,/home/hector/installed/intel/compilers_and_
> libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_thread.a]"
> --with-scalapack-include=/home/hector/installed/intel/
> compilers_and_libraries_2019.0.046/linux/mkl/include
> --with-scalapack-lib="[/home/hector/installed/intel/
> libmkl_scalapack_lp64.a,/home/hector/installed/intel/
> compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a]"
> --with-shared-libraries=0 --FC_LINKER_FLAGS="-qopenmp -qopenmp-link static"
> --FFLAGS="-qopenmp -qopenmp-link static" --LIBS="-Wl,--start-group
> /home/hector/installed/intel/compilers_and_libraries_2019.
> 0.046/linux/mkl/lib/intel64/libmkl_intel_lp64.a
> 0.046/linux/mkl/lib/intel64/libmkl_core.a /home/hector/installed/intel/
> compilers_and_libraries_2019.0.046/linux/mkl/lib/intel64/libmkl_intel_thread.a
> -Wl,--end-group -liomp5 -ldl -lpthread -lm"
> [0]PETSC ERROR: #305869 MatILUFactorSymbolic_SeqBAIJ() line 369 in
> /home/hector/dwnld_prog/petsc/src/mat/impls/baij/seq/baijfact2.c
> [0]PETSC ERROR: #305870 MatILUFactorSymbolic() line 6522 in
> /home/hector/dwnld_prog/petsc/src/mat/interface/matrix.c
> [0]PETSC ERROR: #305871 PCSetUp_ILU() line 144 in
> /home/hector/dwnld_prog/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> [0]PETSC ERROR: #305872 PCSetUp() line 923 in
> /home/hector/dwnld_prog/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #305873 KSPSetUp() line 381 in
> /home/hector/dwnld_prog/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #305874 KSPSolve() line 612 in
> What could be the problem?
For all factorizations, you must have diagonal entries, even if they are 0.
Matt
> Thanks for your help,
> Hector
> On 05/22/2018 06:28 PM, Jed Brown wrote:
> Hector E Barrios Molano <hectorb at utexas.edu> <hectorb at utexas.edu> writes:
> Hi PETSc Experts!
> I am updating a Fortran code that use PETSc 3.7 to version 3.9.2 (from
> git repository).
> Such code declares:
> Mat mat
> and used it as an integer, for example, to assign an initial value and
> test it to know if the matrix has been created by PETSc.
> data mat/-1/
> if (mat .eq. -1) then
> You can use PETSC_NULL_MAT
> With the new PETSc Fortran modules the compiler complains about this and
> stops.
> Is there a better way to achieve this? So that I do not have to set an
> predefined value to Mat type to test if it was already created by PETSc?
> If not, Is there a way to access the value in mat?
> Looking at the source code type(tMat) has "v" variable, so could I used
> as mat%v?
> Please no.
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180523/7854136e/attachment.html>
