[petsc-dev] Proposed changes to TS API
Jed Brown jed at jedbrown.org
Fri May 11 17:26:19 CDT 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>> The current IJacobian is essentially SNESJacobian. And the single-matrix SNESJacobian interface is always there. Power users could set up the SNESJacobian directly if we pass a read-only shift parameter to them. So we are by no means prohibiting power users from doing what they want.
>>>> You mean the user would call TSGetSNES and SNESSetJacobian, then
>>>> internally call TSGetIJacobianShift and some new function to create
>>>> Udot?  That sounds way messier and error-prone.
>>>> And completely impossible to compose. We should be explicitly talking about subsystems that use TS. For example,
>>>> I have a nonlinear system for plasticity. I want to use a preconditioner that introduces some elasticity and timesteps to
>>>> steady state to provide a good Newton direction. I need to to be able to create the solver without all sorts of digging
>>>> in and setting things. This idea that you "just set SNESJacobian" is a non-starter.
>>>   But this is exactly what TSComputeIJacobian currently does, so is the current interface a non-starter?
>> It isn't at all the current interface.
>    You misunderstand what I am saying. The current interface produces exactly the Jacobian needed for the SNES solve (nothing more and nothing less) as a single monolithic matrix. Matt says this is a non-starter.
Matt says that having the user call TSGetSNES and SNESSetJacobian (my
interpretation of Hong's "users could set up the SNESJacobian directly")
to assemble that matrix is a non-starter.
