[petsc-dev] Proposed changes to TS API
Smith, Barry F. bsmith at mcs.anl.gov
Fri May 11 17:18:34 CDT 2018
> On May 11, 2018, at 5:09 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>> The current IJacobian is essentially SNESJacobian. And the single-matrix SNESJacobian interface is always there. Power users could set up the SNESJacobian directly if we pass a read-only shift parameter to them. So we are by no means prohibiting power users from doing what they want.
>>> You mean the user would call TSGetSNES and SNESSetJacobian, then
>>> internally call TSGetIJacobianShift and some new function to create
>>> Udot?  That sounds way messier and error-prone.
>>> And completely impossible to compose. We should be explicitly talking about subsystems that use TS. For example,
>>> I have a nonlinear system for plasticity. I want to use a preconditioner that introduces some elasticity and timesteps to
>>> steady state to provide a good Newton direction. I need to to be able to create the solver without all sorts of digging
>>> in and setting things. This idea that you "just set SNESJacobian" is a non-starter.
>>   But this is exactly what TSComputeIJacobian currently does, so is the current interface a non-starter?
> It isn't at all the current interface.
   You misunderstand what I am saying. The current interface produces exactly the Jacobian needed for the SNES solve (nothing more and nothing less) as a single monolithic matrix. Matt says this is a non-starter.
   Barry
> If the user is calling
> SNESSetJacobian, then we would need to open up the bowels of every
> SNESTSFormJacobian_* and make stable public APIs out of those internals
> (including the wiring for nonlinear multigrid).  This sounds like a
> terrible thing to make public.
