[petsc-dev] calling petsc from a mex file
Munson, Todd
tmunson at mcs.anl.gov
Wed May 9 11:49:23 CDT 2018
There is some issue with my matlab installation. I also tried it on linux and the
simple Petsc initialize and finalize work fine. When I start setting up
and using TaoSolve, I get a segmentation violation.
I am going to switch to using the PetscMatlabEngine, which is what I should
have done from the beginning; that seems to be the safer option.
Note: I compiled the latest Petsc using --with-matlab and changed to the
src/snes/examples/tutorials directory and did a "make ex5". The
compilation works fine, but the "-Wl,-rpath" for the matlab
libraries is missing and I have to set my DYLD_LIBRARY_PATH
manually. I don't know where to fix this in the build
system.
Thanks, Todd.
> On May 9, 2018, at 1:55 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Huh
> $ matlab -nodisplay
> < M A T L A B (R) >
> Copyright 1984-2018 The MathWorks, Inc.
> R2018a (9.4.0.813654) 64-bit (maci64)
> February 23, 2018
> Warning: Name is nonexistent or not a directory: /Users/barrysmith/Src/nodal-dg/Codes1.1
> Warning: Name is nonexistent or not a directory: /Users/barrysmith/Src/nodal-dg/Codes1.1/CFD2D
> To get started, type one of these: helpwin, helpdesk, or demo.
> For product information, visit www.mathworks.com.
>>> taopounders()
>>> exit
> ~/Src/petsc/src/tao/leastsquares/examples/matlab (tmunson/tao-pounders-matlab-interface=) arch-matlab
>> On May 8, 2018, at 2:30 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>> Its in tmunson/tao-pounders-matlab-interface
>> Most of the code is commented out or otherwise inactive. There is a hacked
>> command in src/tao/leastsquares/examples/matlab that I use to compile the
>> mex file.
>> To test, you should be able to start matlab and say "taopounders(); exit".
>> Todd.
>>> On May 8, 2018, at 2:21 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>> Push the branch that does this or send me the code and I'll debug it. I now have some vague memory about this behavior.
>>> Barry
>>>> On May 8, 2018, at 1:53 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>>>>> On May 8, 2018, at 1:02 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>>>>> On May 8, 2018, at 12:30 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
>>>>>> Hi,
>>>>>> I wonder if anyone has experience calling petsc from matlab using mex. I have the
>>>>>> simplest possible mexFunction that just calls PetscInitialize() and
>>>>>> PetscFinalize(). That part seems to work fine, but when I exit
>>>>>> from matlab I get a segmentation violation and a petsc error
>>>>>> message.
>>>>> What are all the error messages? Cut and paste. I've done this in the past but not for years.
>>>> Below is the matlab session and error message. I do note that if I issue PetscFinalize() and
>>>> that command completes, the Petsc signal handlers remain installed/active. If I do a
>>>> PetscPopSignalHandler() immediately after PetscInitialize(), I do not get the error
>>>> message, but a "Segmentation fault: 11" output at the end.
>>>> Because petsc is being loaded as a dynamic library, are there possibly uninitialized global
>>>> variables or state?
>>>> Thanks, Todd.
>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>> [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------
>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>>>> [0]PETSC ERROR: is given.
>>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>>> [0]PETSC ERROR: Signal received
>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9.1-409-gf553c6556e GIT Date: 2018-05-07 17:17:17 -0500
>>>> [0]PETSC ERROR: Unknown Name on a arch-darwin-c-debug named eduroam062-089.wl.anl-external.org by tmunson Tue May 8 12:04:45 2018
>>>> [0]PETSC ERROR: Configure options --download-mpich CC=/usr/bin/clang CXX=/usr/bin/clang++ FC=/opt/local/bin/gfortran
>>>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>>>> system msg for write_line failure : Bad file descriptor
