[petsc-dev] GCC8 Fortran length changes from int to size_t
    Matthew Knepley
    knepley at gmail.com
    Wed May  2 12:18:55 CDT 2018
On Wed, May 2, 2018 at 1:14 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, May 2, 2018 at 12:15 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> Lisandro Dalcin <dalcinl at gmail.com> writes:
> >> > On Wed, 2 May 2018 at 17:29, Satish Balay <balay at mcs.anl.gov> wrote:
> >> >> So we need a 64bit arm with gcc8 - for this testcase failure?
> >> > Or a big-endian machine/OS ?
> >> Shouldn't be necessary, but why are we so concerned about making a test
> >> case fail instead of implementing correct behavior?
> > How would you know your fix was correct?
> Documentation and/or reading assembly.
Its good that tests are superfluous for code you write because it conforms
to standards and
you check the assembly. We should take out all the SF tests. That would
decrease runtime.
   Matt
>   I don't have gfortran-8
> installed yet, but Satish says he does so I offered a tiny snippet that
> can be used to confirm that the documentation isn't lying.  If you
> really care to make code crash, we can do that too (as I described).
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180502/ee6032d7/attachment.html>
