[petsc-dev] MPI I/O tests failing in master after merging my branch
Matthew Knepley
knepley at gmail.com
Thu Mar 22 07:17:19 CDT 2018
On Thu, Mar 22, 2018 at 7:09 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Thu, Mar 22, 2018 at 6:15 AM, Lisandro Dalcin <dalcinl at gmail.com>
> wrote:
> >> On 22 March 2018 at 12:51, Matthew Knepley <knepley at gmail.com> wrote:
> >> > On Thu, Mar 22, 2018 at 3:44 AM, Lisandro Dalcin <dalcinl at gmail.com>
> >> wrote:
> >> >> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> >> 2018/03/21/examples_master_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
> >> >> The thing is, PETSc does not currently have a way of mapping a plain
> C
> >> >> `int` type to a PETSc datatype. I'm wiling to take the required work
> >> >> to fix this issue.
> >> > Is this not what PetscMPIInt is for?
> >> No, not at all, PetscMPIInt it not even mentioned in the PetscDatatype
> >> enumeration. The whole PetscDatatype this is kind of messy, and fixing
> >> it should take some time, and this for sure will no make my h-index
> >> explode, right?. For now, mapping MPI_INT -> PETSC_ENUM seems
> >> workaround the issue just fine.
> > What I meant was, we already have a typedef 'PetscMPIInt' which is
> supposed
> > to reproduce MPI_INT, so why not add PETSC_MPI_INT to the PetscDataTypes
> > rather than map MPI_INT to PetscEnum?
> https://bitbucket.org/petsc/petsc/issues/188/remove-use-of-petscdatatype
I agree, but this was about short term fixing.
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180322/dd1f859e/attachment.html>
