[petsc-dev] MPI I/O tests failing in master after merging my branch
Jed Brown jed at jedbrown.org
Thu Mar 22 06:09:01 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
> On Thu, Mar 22, 2018 at 6:15 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> On 22 March 2018 at 12:51, Matthew Knepley <knepley at gmail.com> wrote:
>> > On Thu, Mar 22, 2018 at 3:44 AM, Lisandro Dalcin <dalcinl at gmail.com>
>> wrote:
>> >> ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
>> 2018/03/21/examples_master_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
>> >> The thing is, PETSc does not currently have a way of mapping a plain C
>> >> `int` type to a PETSc datatype. I'm wiling to take the required work
>> >> to fix this issue.
>> > Is this not what PetscMPIInt is for?
>> No, not at all, PetscMPIInt it not even mentioned in the PetscDatatype
>> enumeration. The whole PetscDatatype this is kind of messy, and fixing
>> it should take some time, and this for sure will no make my h-index
>> explode, right?. For now, mapping MPI_INT -> PETSC_ENUM seems
>> workaround the issue just fine.
> What I meant was, we already have a typedef 'PetscMPIInt' which is supposed
> to reproduce MPI_INT, so why not add PETSC_MPI_INT to the PetscDataTypes
> rather than map MPI_INT to PetscEnum?
https://bitbucket.org/petsc/petsc/issues/188/remove-use-of-petscdatatype
