[petsc-dev] Is ./configure --help broken?
Jed Brown jed at jedbrown.org
Fri Mar 16 13:20:17 CDT 2018
Matthew Knepley <knepley at gmail.com> writes:
>> >> > I agree. We should remove all code (about 2/3 of it) which does a
>> >> > hierarchy of communicating dicts (the original design). That would
>> >> > make everything simple.  No threads, no parents, etc. We leave in the
>> >> > help the way we want it, types for args, etc. One thing its notably
>> >> > missing, and that PETSc Options are missing, is listing the thing that
>> >> > set the option (default, command line, code, env).
>> >> Does RDict even need to be persistent?  Who all reads it?  I wonder if
>> >> an existing human-readable file would be sufficient instead?
>> > I think we should persist the entire set of options used to configure for
>> > later
>> > interrogation, however we have not done that much so far.
>> CONFIGURE_OPTIONS is written to petscvariables and printed by make info.
>> I think fewer duplications is desirable.
> This gets into a separate discussion. I think Python info is more useful
> since its
> directly visible to scripts we might write.
Just call your Python parsing function.  But this gets back to my
earlier question: who needs to read RDict.db and for what purpose?
