[petsc-dev] Is ./configure --help broken?
Matthew Knepley
knepley at gmail.com
Fri Mar 16 13:12:39 CDT 2018
On Fri, Mar 16, 2018 at 1:27 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> > I agree. We should remove all code (about 2/3 of it) which does a
> >> > hierarchy of communicating dicts (the original design). That would
> >> > make everything simple. No threads, no parents, etc. We leave in the
> >> > help the way we want it, types for args, etc. One thing its notably
> >> > missing, and that PETSc Options are missing, is listing the thing that
> >> > set the option (default, command line, code, env).
> >> Does RDict even need to be persistent? Who all reads it? I wonder if
> >> an existing human-readable file would be sufficient instead?
> > I think we should persist the entire set of options used to configure for
> > later
> > interrogation, however we have not done that much so far.
> CONFIGURE_OPTIONS is written to petscvariables and printed by make info.
> I think fewer duplications is desirable.
This gets into a separate discussion. I think Python info is more useful
since its
directly visible to scripts we might write.
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180316/a6e26970/attachment.html>
