[petsc-dev] Stale lib/petsc/conf/petscvariables interferes with prefix tests
Satish Balay
balay at mcs.anl.gov
Thu Mar 8 16:26:59 CST 2018
On Thu, 8 Mar 2018, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> Related question: if the prefix install is read-only, then this line in
> >> "make info" fails.
> >> - at echo Using mpi.h: `echo '#include <mpi.h>' > ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/mpitest.c; ${CPP} ${PETSC_CCPPFLAGS} ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/mpitest.c |grep 'mpi\.h' | ( head -1 ; cat > /dev/null )`
> > Hm - this is primarily used by 'make all' - [that should always have write access to ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/]
> > And I see we've previously used it from testexamples, testfortran etc targets - but these should now be removed?
> >> Are there CPP that can't use stdin?
> > Windows.
> Yuck, so I should discard this commit and we just ask people not to call
> "make info" with a prefix install? I ran into this while testing the
> previous commit -- it was easier to run "make info" than "make install".
> https://bitbucket.org/petsc/petsc/commits/6a7405f8e8874e272f9c21704f3a2fdb6ad1a9b1
But 'make info' is not used after the build - so should we worry about getting this working after the build?
Alternative would be to use /tmp - but I hesitated to do that.. [as I
would have to cleanly delete things I write there, worry about
multiple concurrent builds etc..]
Satish
