[petsc-dev] Stale lib/petsc/conf/petscvariables interferes with prefix tests
Jed Brown
jed at jedbrown.org
Thu Mar 8 16:21:11 CST 2018
Satish Balay <balay at mcs.anl.gov> writes:
>> Related question: if the prefix install is read-only, then this line in
>> "make info" fails.
>> - at echo Using mpi.h: `echo '#include <mpi.h>' > ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/mpitest.c; ${CPP} ${PETSC_CCPPFLAGS} ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/mpitest.c |grep 'mpi\.h' | ( head -1 ; cat > /dev/null )`
> Hm - this is primarily used by 'make all' - [that should always have write access to ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/]
> And I see we've previously used it from testexamples, testfortran etc targets - but these should now be removed?
>> Are there CPP that can't use stdin?
> Windows.
Yuck, so I should discard this commit and we just ask people not to call
"make info" with a prefix install? I ran into this while testing the
previous commit -- it was easier to run "make info" than "make install".
https://bitbucket.org/petsc/petsc/commits/6a7405f8e8874e272f9c21704f3a2fdb6ad1a9b1
