[petsc-dev] building with MKL
    Mark Adams
    mfadams at lbl.gov
    Sat Jun 30 14:55:24 CDT 2018
It builds and runs but looks like PETSc does not register aijmkl matrices.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Unknown type. Check for miss-spelling or missing package:
http://www.mcs.anl.gov/petsc/documentation/installation.html#external
> [0]PETSC ERROR: Unknown Mat type given: aijmkl
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.2, unknown
> [0]PETSC ERROR:
/global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/./ex19
on a  named nid02516 by madams Sat Jun 30 12:48:10 2018
> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
--known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
--known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
--known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
--known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
--known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
--known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
--known-mpi-c-double-complex=1 --known-has-attribute-aligned=1 --with-cc=cc
--with-cxx=CC --with-fc=ftn COPTFLAGS="  -g -O0 -hcpu=mic-knl
-qopenmp-simd" CXXOPTFLAGS="-g -O0 -hcpu=mic-knl -qopenmp-simd"
FOPTFLAGS="  -g -O0 -hcpu=mic-knl -qopenmp-simd" --download-metis=1
--with-hypre-dir=/global/homes/m/madams/tmp/hypre-2.14.0
--download-parmetis=1
--with-blaslapack-lib=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a
--with-debugging=1 --with-mpiexec=srun --with-batch=1
--known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0
--with-64-bit-indices=1 PETSC_ARCH=arch-cori-knl-dbg64-intel-omp
--with-openmp=1 --download-p4est=0 --with-x=0
--prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp
PETSC_DIR=/global/homes/m/madams/petsc_install/petsc
> [0]PETSC ERROR: #1 MatSetType() line 61 in
/global/u2/m/madams/petsc_install/petsc/src/mat/interface/matreg.c
> [0]PETSC ERROR: #2 MatSetFromOptions() line 229 in
/global/u2/m/madams/petsc_install/petsc/src/mat/utils/gcreate.c
> [0]PETSC ERROR: #3 DMCreateMatrix_DA() line 793 in
/global/u2/m/madams/petsc_install/petsc/src/dm/impls/da/fdda.c
> [0]PETSC ERROR: #4 DMCreateMatrix() line 1262 in
/global/u2/m/madams/petsc_install/petsc/src/dm/interface/dm.c
> [0]PETSC ERROR: #5 SNESSetUpMatrices() line 646 in
/global/u2/m/madams/petsc_install/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #6 SNESSetUp_NEWTONLS() line 296 in
/global/u2/m/madams/petsc_install/petsc/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #7 SNESSetUp() line 2908 in
> [0]PETSC ERROR: #8 SNESSolve() line 4300 in
> [0]PETSC ERROR: #9 main() line 161 in
/global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex19.c
> [0]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -da_refine 3
> [0]PETSC ERROR: -ksp_monitor
> [0]PETSC ERROR: -mat_type aijmkl
> [0]PETSC ERROR: -options_left
> [0]PETSC ERROR: -pc_type gamg
> [0]PETSC ERROR: -snes_monitor_short
> [0]PETSC ERROR: -snes_view
> [0]PETSC ERROR: ----------------End of Error Message -------se
On Sat, Jun 30, 2018 at 3:08 PM Mark Adams <mfadams at lbl.gov> wrote:
> OK, that got further.
> On Sat, Jun 30, 2018 at 3:03 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Like this?
>> '--with-blaslapack-lib=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64/libmkl_intel_thread.a',
>> On Sat, Jun 30, 2018 at 3:00 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Specify either "--with-blaslapack-dir" or "--with-blaslapack-lib
>>>>> --with-blaslapack-include". But not both!
>>>> Get rid of the dir option, and give the full path to the library.
>>> What is the syntax for giving the full path?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180630/39fcb6a3/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180630/39fcb6a3/attachment-0001.obj>
