[petsc-dev] building with MKL
Mark Adams
mfadams at lbl.gov
Sat Jun 30 12:25:24 CDT 2018
Found a syntax error from Intel web page and --with-blaslapack-lib to
specify the library. Press on.
On Sat, Jun 30, 2018 at 11:50 AM Mark Adams <mfadams at lbl.gov> wrote:
> I am configuring with MKL:
> '--with-blas-lapack-dir=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin',
> '--with-mkl_pardiso-dir=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin',
> and get this error (appended). It is looking for libmkl_intel.a but this
> is what there is:
> 08:46 cori07 maint *= ~/petsc_install/petsc/src/snes/examples/tutorials$
> ll
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_inte*
> -rw-r--r-- 1 root root 22133402 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_ilp64.a
> -rwxr-xr-x 1 root root 9783841 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_ilp64.so
> -rw-r--r-- 1 root root 23254666 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.a
> -rwxr-xr-x 1 root root 10567885 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.so
> -rw-r--r-- 1 root root 49087274 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_thread.a
> -rwxr-xr-x 1 root root 37230319 Oct 6 2017
> /opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin/libmkl_intel_thread.so
> I would guess I want to add and LDFLAGS="lmkl_intel_thread" maybe? I want
> to use OpenMP.
> Thanks,
> Mark
> Pushing language C
> Popping language C
> Executing: cc -o /tmp/petsc-ZL05ng/config.libraries/conftest -g -O0
> -hcpu=mic-knl -qopenmp-simd -fopenmp
> /tmp/petsc-ZL05ng/config.libraries/conftest.o
> -Wl,-rpath,/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin
> -L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64_lin
> -lmkl_intel -lmkl_core -lmkl_gnu_thread -lgomp -ldl -lpthread -lstdc++ -ldl
> Possible ERROR while running linker: exit code 256
> stderr:
> /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld:
> cannot find -lmkl_intel
> Popping language C
> Unknown name mangling in BLAS/LAPACK
> **** Configure header /tmp/petsc-ZL05ng/confdefs.h ****
> #if !defined(INCLUDED_UNKNOWN)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180630/1c03786f/attachment.html>
