[petsc-dev] problem with hypre with '--with-openmp=1'
Mark Adams
mfadams at lbl.gov
Tue Jun 26 08:26:36 CDT 2018
On Tue, Jun 26, 2018 at 12:19 AM Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> Mark,
> Your email reminded me my recent experiments. My PETSc was configured --with-openmp=1.
> With hypre, my job ran out of time. That was on an Argonne Xeon cluster.
Interesting. I tested on Cori's Haswell nodes and it looked fine. I did not
time it but seemed OK.
> I repeated the experiments on Cori's Haswell nodes. --with-openmp=1,
> "Linear solve converged due to CONVERGED_RTOL iterations 5". But it took
> very long time (10 mins). Without --with-openmp=1, it took less than 1
> second.
Humm. I seemed to run OK on Cori's Haswell nodes. Where you running a
significant sized job? I was test small serial runs.
> --Junchao Zhang
> On Fri, Jun 22, 2018 at 3:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> We are using KNL (Cori) and hypre is not working when configured
>> with '--with-openmp=1', even when not using threads (as far as I can tell,
>> I never use threads).
>> Hypre is not converging, for instance with an optimized build:
>> srun -n 1 ./ex56 -pc_type hypre -ksp_monitor -ksp_converged_reason
>> -ksp_type cg -pc_hypre_type boomeramg
>> OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
>> 0 KSP Residual norm 7.366251922394e+22
>> 1 KSP Residual norm 3.676434682799e+22
>> Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 2
>> Interestingly in debug mode it almost looks good but it is dying:
>> 05:09 nid02516 maint *=
>> ~/petsc_install/petsc/src/ksp/ksp/examples/tutorials$ make
>> PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp
>> PETSC_ARCH="" run
>> 0 KSP Residual norm 7.882081712007e+02
>> 1 KSP Residual norm 2.500214073037e+02
>> 2 KSP Residual norm 3.371746347713e+01
>> 3 KSP Residual norm 2.918759396143e+00
>> 4 KSP Residual norm 9.006505495017e-01
>> Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 5
>> This test runs fine on Xeon nodes. I assume that Hypre has been tested on
>> KNL. GAMG runs fine, of coarse and the initial residual is similar to this
>> debug run.
>> Could PETSc be messing up the matrix conversion to hypre
>> '--with-openmp=1' ?
>> Any ideas?
>> Thanks,
>> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180626/2f713bf8/attachment-0001.html>
