[petsc-dev] problem with hypre with '--with-openmp=1'
Junchao Zhang jczhang at mcs.anl.gov
Mon Jun 25 23:19:21 CDT 2018
Mark,
  Your email reminded me my recent experiments. My PETSc was
configured --with-openmp=1.
With hypre, my job ran out of time. That was on an Argonne Xeon cluster.
  I repeated the experiments on Cori's Haswell nodes.  --with-openmp=1,
"Linear solve converged due to CONVERGED_RTOL iterations 5". But it took
very long time (10 mins). Without --with-openmp=1, it took less than 1
second.
--Junchao Zhang
On Fri, Jun 22, 2018 at 3:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
> We are using KNL (Cori) and hypre is not working when configured
> with  '--with-openmp=1', even when not using threads (as far as I can tell,
> I never use threads).
> Hypre is not converging, for instance with an optimized build:
> srun -n 1 ./ex56 -pc_type hypre -ksp_monitor -ksp_converged_reason
> -ksp_type cg -pc_hypre_type boomeramg
> OMP: Warning #239: KMP_AFFINITY: granularity=fine will be used.
>   0 KSP Residual norm 7.366251922394e+22
>   1 KSP Residual norm 3.676434682799e+22
> Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 2
> Interestingly in debug mode it almost looks good but it is dying:
> 05:09 nid02516 maint *= ~/petsc_install/petsc/src/ksp/ksp/examples/tutorials$
> make PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-knl-dbg64-intel-omp
> PETSC_ARCH="" run
>   0 KSP Residual norm 7.882081712007e+02
>   1 KSP Residual norm 2.500214073037e+02
>   2 KSP Residual norm 3.371746347713e+01
>   3 KSP Residual norm 2.918759396143e+00
>   4 KSP Residual norm 9.006505495017e-01
> Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 5
> This test runs fine on Xeon nodes. I assume that Hypre has been tested on
> KNL. GAMG runs fine, of coarse and the initial residual is similar to this
> debug run.
> Could PETSc be messing up the matrix conversion to hypre '--with-openmp=1'
> Any ideas?
> Thanks,
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180625/f7c6859e/attachment.html>
