[petsc-dev] GAMG key not found in table
    Mark Adams
    mfadams at lbl.gov
    Sun Jun 24 11:15:56 CDT 2018
First, -pc_gamg_threshold 0.8  is crazy. 0.08 is very high. probably best
to start with 0.
This threshold will delete all of your edges in the coarsening graph,
probably, and GAMG will switch to a one level solve (silently although
-info will tell you).
And yes, this looks like a 64 bit indices problem, we have:
#define GAMG_HASH(key) ((((PetscInt)7)*key)%a_tab->size)
We should probably cast everything to (long long) or (unsigned PetscInt) I
guess ... I'm not sure how this should be done exactly.  Any ideas from the
peanut gallery?
On Sun, Jun 24, 2018 at 2:34 AM Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> Any ideas on how to debug this?
> [406]PETSC ERROR: key 328214936 not found in table
> [406]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [406]PETSC ERROR: Petsc Development GIT revision: v3.9.2-603-gceafe64  GIT
> Date: 2018-06-10 12:46:16 -0500
> [406]PETSC ERROR:
> /ccc/work/cont003/rndm/rndm/FreeFem-sources/src/mpi/FreeFem++-mpi on a
> arch-linux2-c-debug-bullxmpi named curie2698 by jolivetp Sun Jun 24
> 07:06:07 2018
> [406]PETSC ERROR: Configure options --with-scalar-type=real
> --with-hypre-dir=arch-linux2-c-opt-bullxmpi
> --with-metis-dir=arch-linux2-c-opt-bullxmpi
> --with-mumps-dir=arch-linux2-c-opt-bullxmpi --with-mkl_cpardiso=1
> --with-mkl_pardiso=1 --with-parmetis-dir=arch-linux2-c-opt-bullxmpi
> --with-ptscotch-dir=arch-linux2-c-opt-bullxmpi
> --with-sowing-dir=arch-linux2-c-opt-bullxmpi
> --with-blacs-include=/ccc/products/mkl-18.0.1.163/default/
> 18.0.1.163/mkl/include
> --with-blacs-lib=/ccc/products/mkl-18.0.1.163/default/
> 18.0.1.163/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so
> --with-blaslapack-dir=/ccc/products/mkl-18.0.1.163/default/
> 18.0.1.163/mkl/lib/intel64 --with-x=0 --with-debugging=1
> --with-errorchecking=1
> --with-mkl_pardiso-dir=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl
> --with-mkl_cpardiso-dir=/ccc/products/mkl-18.0.1.163/default/
> 18.0.1.163/mkl
> --with-scalapack-include=/ccc/products/mkl-18.0.1.163/default/
> --with-scalapack-lib="[/ccc/products/mkl-18.0.1.163/default/
> 18.0.1.163/mkl/lib/intel64/libmkl_scalapack_lp64.so,/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so]"
> --with-fortran-bindings=0 PETSC_ARCH=arch-linux2-c-debug-bullxmpi
> [406]PETSC ERROR: #1 PCGAMGHashTableFind() line 106 in
> /ccc/work/cont003/rndm/rndm/petsc/include/petsc/private/pcgamgimpl.h
> [406]PETSC ERROR: #2 smoothAggs() line 526 in
> /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/impls/gamg/agg.c
> [406]PETSC ERROR: #3 PCGAMGCoarsen_AGG() line 970 in
> [406]PETSC ERROR: #4 PCSetUp_GAMG() line 518 in
> /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/impls/gamg/gamg.c
> [406]PETSC ERROR: #5 PCSetUp() line 932 in
> /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/interface/precon.c
> [406]PETSC ERROR: #6 KSPSetUp() line 381 in
> /ccc/work/cont003/rndm/rndm/petsc/src/ksp/ksp/interface/itfunc.c
> For smaller problems, this works fine. Should I compile using 64 bit
> indices?
> I’m using -pc_type gamg -pc_gamg_threshold 0.8 -pc_gamg_agg_nsmooths 1
> -pc_gamg_sym_graph true -pc_gamg_square_graph 10
> Thanks,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180624/46b6579f/attachment.html>
