[petsc-dev] GAMG key not found in table
    Pierre Jolivet
    pierre.jolivet at enseeiht.fr
    Sun Jun 24 01:33:48 CDT 2018
Hello,
Any ideas on how to debug this?
[406]PETSC ERROR: key 328214936 not found in table
[406]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[406]PETSC ERROR: Petsc Development GIT revision: v3.9.2-603-gceafe64  GIT Date: 2018-06-10 12:46:16 -0500
[406]PETSC ERROR: /ccc/work/cont003/rndm/rndm/FreeFem-sources/src/mpi/FreeFem++-mpi on a arch-linux2-c-debug-bullxmpi named curie2698 by jolivetp Sun Jun 24 07:06:07 2018
[406]PETSC ERROR: Configure options --with-scalar-type=real --with-hypre-dir=arch-linux2-c-opt-bullxmpi --with-metis-dir=arch-linux2-c-opt-bullxmpi --with-mumps-dir=arch-linux2-c-opt-bullxmpi --with-mkl_cpardiso=1 --with-mkl_pardiso=1 --with-parmetis-dir=arch-linux2-c-opt-bullxmpi --with-ptscotch-dir=arch-linux2-c-opt-bullxmpi --with-sowing-dir=arch-linux2-c-opt-bullxmpi --with-blacs-include=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/include --with-blacs-lib=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so --with-blaslapack-dir=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/lib/intel64 --with-x=0 --with-debugging=1 --with-errorchecking=1 --with-mkl_pardiso-dir=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl --with-mkl_cpardiso-dir=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl --with-scalapack-include=/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/include --with-scalapack-lib="[/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/lib/intel64/libmkl_scalapack_lp64.so,/ccc/products/mkl-18.0.1.163/default/18.0.1.163/mkl/lib/intel64/libmkl_blacs_openmpi_lp64.so]" --with-fortran-bindings=0 PETSC_ARCH=arch-linux2-c-debug-bullxmpi
[406]PETSC ERROR: #1 PCGAMGHashTableFind() line 106 in /ccc/work/cont003/rndm/rndm/petsc/include/petsc/private/pcgamgimpl.h
[406]PETSC ERROR: #2 smoothAggs() line 526 in /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/impls/gamg/agg.c
[406]PETSC ERROR: #3 PCGAMGCoarsen_AGG() line 970 in /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/impls/gamg/agg.c
[406]PETSC ERROR: #4 PCSetUp_GAMG() line 518 in /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/impls/gamg/gamg.c
[406]PETSC ERROR: #5 PCSetUp() line 932 in /ccc/work/cont003/rndm/rndm/petsc/src/ksp/pc/interface/precon.c
[406]PETSC ERROR: #6 KSPSetUp() line 381 in /ccc/work/cont003/rndm/rndm/petsc/src/ksp/ksp/interface/itfunc.c
For smaller problems, this works fine. Should I compile using 64 bit indices?
I’m using -pc_type gamg -pc_gamg_threshold 0.8 -pc_gamg_agg_nsmooths 1 -pc_gamg_sym_graph true -pc_gamg_square_graph 10
Pierre
