[petsc-dev] Expensive VecDuplicate_MPI_DA
Junchao Zhang
jczhang at mcs.anl.gov
Wed Jun 20 13:02:15 CDT 2018
One of 6 MatSOR's generates a VecDuplicate_MPI_DA. They are more VecDuplicates
in MatSOR, but some of them go to VecDuplicate_MPI for reason I don't know.
--Junchao Zhang
On Wed, Jun 20, 2018 at 12:52 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
wrote:
> > On Jun 20, 2018, at 11:35 AM, Zhang, Junchao <jczhang at mcs.anl.gov>
> wrote:
> > I added a workaround to avoid collective calls in VecDuplicate. With 216
> cores, it improved the code's performance by 5%.
> Wow
> Is every call to MatSOR generating a VecDuplicate/VecDestroy pair?
> Barry
> > I can imagine more improvement with more cores. But more importantly,
> the "Reduction count" of MatSOR in -log_view is zero now instead of some
> misleading number.
> > BTW, it does not solve the imbalance problem of MatSOR which I am
> debugging.
> > --Junchao Zhang
> > On Tue, Jun 19, 2018 at 10:58 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > Ahh yes. Since the layout can get large we wanted to avoid each vector
> having its own copy.
> > But it seems sloppy since DMCreateGlobalVector_DA() does keep a new
> copy for each vector.
> > We could revisit the entire VecDuplicate/DMCreateGlobalVector()
> infrastructure for all the vector types including the DM ones to
> > 1) prevent collective calls
> > 2) reference the layout instead of making new ones.
> > Barry
> > It looks like VecDuplicate_MPI() does the right thing.
> > > On Jun 19, 2018, at 10:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> > >> Jed,
> > >> You added these two lines. Any idea why they are needed?
> > > That was just replacing the old interface
> > > https://bitbucket.org/petsc/petsc/commits/
> 077aedaf8cb5b060ad5dab7a12035daf9d64dd75#Lsrc/dm/impls/da/dadist.cF19
> > > that you added here
> 5ead1ec26b293130cbc6f8fa84f0a9ffce38a0bf
> > >> Thanks
> > >> Barry
> > >> 3e08d2bebf99 src/dm/impls/da/dadist.c (Barry Smith
> 2012-09-18 14) PetscFunctionBegin;
> > >> c688c0463f6c src/dm/impls/da/dadist.c (Matthew Knepley
> 2012-11-11 15) ierr = VecGetDM(g, &da);CHKERRQ(ierr);
> > >> 2dcb2ebcaafe src/dm/impls/da/dadist.c (Barry Smith
> 2010-10-31 16) ierr = DMCreateGlobalVector(da,gg);CHKERRQ(ierr);
> > >> 077aedaf8cb5 src/dm/impls/da/dadist.c (Jed Brown
> 2013-02-11 17) ierr = VecGetLayout(g,&map);CHKERRQ(ierr);
> 2013-02-11 18) ierr = VecSetLayout(*gg,map);CHKERRQ(ierr);
> 2010-10-31 19) PetscFunctionReturn(0)
> > >> If we were a bit more clever we could probably avoid all
> communication in VecDuplicate() but is it worth bothering unless we know it
> is problematic
> > >>> On Jun 19, 2018, at 4:30 PM, Junchao Zhang <jczhang at mcs.anl.gov>
> wrote:
> > >>> I met an expensive VecDuplicate. See the attached call stack.
> VecDuplicate_MPI_DA indirectly calls MPI_Allreduce/Allgather to build the
> vector's layout, but it then immediately destroys it with VecGetLayout &
> VecSetLayout. Is it wrong?
> > >>> PetscErrorCode VecDuplicate_MPI_DA(Vec g,Vec *gg)
> > >>> PetscErrorCode ierr;
> > >>> DM da;
> > >>> PetscLayout map;
> > >>> PetscFunctionBegin;
> > >>> PetscFunctionReturn(0);
> > >>> --Junchao Zhang
> > >>> <VecDup.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180620/0c741af9/attachment.html>
