[petsc-dev] Expensive VecDuplicate_MPI_DA
Smith, Barry F. bsmith at mcs.anl.gov
Wed Jun 20 12:52:17 CDT 2018
> On Jun 20, 2018, at 11:35 AM, Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> I added a workaround to avoid collective calls in VecDuplicate. With 216 cores, it improved the code's performance by 5%.
  Wow
   Is every call to MatSOR generating a VecDuplicate/VecDestroy pair?
   Barry
>  I can imagine more improvement with more cores. But more importantly, the "Reduction count" of MatSOR in -log_view is zero now instead of some misleading number.
> BTW, it does not solve the imbalance problem of MatSOR which I am debugging.
> --Junchao Zhang
> On Tue, Jun 19, 2018 at 10:58 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Ahh yes. Since the layout can get large we wanted to avoid each vector having its own copy.
>    But it seems sloppy since DMCreateGlobalVector_DA() does keep a new copy for each vector.
>    We could revisit the entire VecDuplicate/DMCreateGlobalVector() infrastructure for all the vector types including the DM ones to
> 1) prevent collective calls
> 2) reference the layout instead of making new ones.
>   Barry
> It looks like VecDuplicate_MPI() does the right thing.
> > On Jun 19, 2018, at 10:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> > "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
> >>   Jed,
> >>     You added these two lines. Any idea why they are needed?
> > That was just replacing the old interface
> > https://bitbucket.org/petsc/petsc/commits/077aedaf8cb5b060ad5dab7a12035daf9d64dd75#Lsrc/dm/impls/da/dadist.cF19
> > that you added here
> > https://bitbucket.org/petsc/petsc/commits/5ead1ec26b293130cbc6f8fa84f0a9ffce38a0bf
> >>    Thanks
> >>    Barry
> >> 3e08d2bebf99 src/dm/impls/da/dadist.c (Barry Smith          2012-09-18  14)   PetscFunctionBegin;
> >> c688c0463f6c src/dm/impls/da/dadist.c (Matthew Knepley      2012-11-11  15)   ierr = VecGetDM(g, &da);CHKERRQ(ierr);
> >> 2dcb2ebcaafe src/dm/impls/da/dadist.c (Barry Smith          2010-10-31  16)   ierr = DMCreateGlobalVector(da,gg);CHKERRQ(ierr);
> >> 077aedaf8cb5 src/dm/impls/da/dadist.c (Jed Brown            2013-02-11  17)   ierr = VecGetLayout(g,&map);CHKERRQ(ierr);
> >> 077aedaf8cb5 src/dm/impls/da/dadist.c (Jed Brown            2013-02-11  18)   ierr = VecSetLayout(*gg,map);CHKERRQ(ierr);
> >> 2dcb2ebcaafe src/dm/impls/da/dadist.c (Barry Smith          2010-10-31  19)   PetscFunctionReturn(0)
> >>   If we were a bit more clever we could probably avoid all communication in VecDuplicate() but is it worth bothering unless we know it is problematic
> >>> On Jun 19, 2018, at 4:30 PM, Junchao Zhang <jczhang at mcs.anl.gov> wrote:
> >>> I met an expensive VecDuplicate. See the attached call stack. VecDuplicate_MPI_DA indirectly calls MPI_Allreduce/Allgather to build the vector's layout, but it then immediately destroys it with VecGetLayout & VecSetLayout. Is it wrong?
> >>> PetscErrorCode  VecDuplicate_MPI_DA(Vec g,Vec *gg)
> >>>  PetscErrorCode ierr;
> >>>  DM             da;
> >>>  PetscLayout    map;
> >>>  PetscFunctionBegin;
> >>>  PetscFunctionReturn(0);
> >>> --Junchao Zhang
> >>> <VecDup.png>
