[petsc-dev] Testing system
Fande Kong fdkong.jd at gmail.com
Wed Jun 6 18:09:14 CDT 2018
Thanks, Patrick, and Jed,
I appended the following to src/mat/examples/tutorials/ex15.c. Also added
the output files: src/mat/examples/tutorials/output/ex15_3.out
and src/mat/examples/tutorials/output/ex15_4.out.
*   test:*
*      suffix: 3*
*      nsize: 4*
*      requires: party*
*      args: -mat_partitioning_type party*
*   test:*
*      suffix: 4*
*      nsize: 3*
*      requires: chaco*
*      args: -mat_partitioning_type chaco*
What are the right instructions I should follow to check if the added tests
are actually working?
Fande,
On Wed, Jun 6, 2018 at 4:59 PM, Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> And for more info
>     make -f gmakefile.test help-test
> 2018-06-06 23:55 GMT+01:00 Jed Brown <jed at jedbrown.org>:
>> Use search, as in
>> make -f gmakefile test search=mat_%
>> Often you'll want to be more specific.
>> "Kong, Fande" <fande.kong at inl.gov> writes:
>> > How to run tests for Mat examples only?
>> >  "make PETSC_ARCH=arch-darwin-c-opt-3.9.2  -f gmakefile.test test" run
>> > everything.
>> > Thanks,
>> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180606/f84b444b/attachment.html>
