[petsc-dev] Testing system
Patrick Sanan patrick.sanan at gmail.com
Wed Jun 6 17:59:54 CDT 2018
And for more info
    make -f gmakefile.test help-test
2018-06-06 23:55 GMT+01:00 Jed Brown <jed at jedbrown.org>:
> Use search, as in
> make -f gmakefile test search=mat_%
> Often you'll want to be more specific.
> "Kong, Fande" <fande.kong at inl.gov> writes:
> > How to run tests for Mat examples only?
> >  "make PETSC_ARCH=arch-darwin-c-opt-3.9.2  -f gmakefile.test test" run
> > everything.
> > Thanks,
> > Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180606/e75700c2/attachment.html>
