[petsc-dev] changes for petsc tests for XL Fortran compiler
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Jun 1 09:51:52 CDT 2018
Serban,
Thanks for the patches. We'll get fixes into the maint branch and hence the next patch release.
Satish,
We have the macro PetscFlush() that should be used for the call flush(6) locations to make the Fortran example code portable. (But needs to be tested since currently it is not used).
Barry
> On Jun 1, 2018, at 9:21 AM, Serban Maerean <serban at us.ibm.com> wrote:
> Hello,
> FYI, I needed to build PETSc test cases with the XL Fortran compiler and had to make the following changes, in <petsc install directory>/share/petsc/examples/: .
> The reasons for these changes was to be able to build w/the XL Fortran compiler (and w/out Fortran name mangling, which is the default for the XL Fortran compiler.)
> Let me know if you have any questions.
> Thanks,
> Serban Maerean
> HPC Tools
> T/L: 293-9770, Tel.: 845-433-9770
> E-mail: serban at us.ibm.com
> <xlc-test-3.9.0.diff>
