[petsc-dev] changes for petsc tests for XL Fortran compiler
    Serban Maerean
    serban at us.ibm.com
    Fri Jun  1 09:21:15 CDT 2018
Hello,
FYI, I needed to build PETSc test cases with the XL Fortran compiler and
had to make the following changes, in <petsc install directory>/
share/petsc/examples/: .
The reasons for these changes was to be able to build w/the XL Fortran
compiler (and w/out Fortran name mangling, which is the default for the XL
Fortran compiler.)
Let me know if you have any questions.
Serban Maerean
HPC Tools
T/L: 293-9770, Tel.: 845-433-9770
E-mail: serban at us.ibm.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180601/31aca009/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180601/31aca009/attachment.obj>
