[petsc-dev] Bad scaling of GAMG in FieldSplit
Mark Adams
mfadams at lbl.gov
Fri Jul 27 10:21:35 CDT 2018
> Everything is fine with GAMG I think, please find the (trimmed) -eps_view
> attached.
This looks fine. The eigen estimates are pretty low, but I don't know what
they really are.
> The problem is that, correct me if I’m wrong, there is no easy way to
> redistribute data efficiently from within PETSc when using fieldsplit with
> unbalanced number of unknowns per field.
Note, as you scale up the coarse grids become more important re complexity.
So the process reduction and potential repartitioning will become more
noticable. At extreme scale you can spend a majority of the time in the
coarse grids.
> For the other three fields, the solvers are still behaving somehow
> properly. Now if I’d like to optimize this some more, I’d probably need to
> switch from a fieldsplit to a MatNest, with submatrices from different
> communicators, so that I don’t have all processes handling the pressure
> space. But this is apparently not allowed.
> Thanks,
> Pierre
>> >> 2) have the sub_0_ and the sub_1_ work on two different nonoverlapping
>>> communicators of size PETSC_COMM_WORLD/2, do the solve concurrently, and
>>> then sum the solutions (only worth doing because of -pc_composite_type
>>> additive). I have no idea if this easily doable with PETSc command line
>>> arguments
>>> > 1) is the more flexible approach, as you have better control over the
>>> system sizes after 'telescoping’.
>>> Right, but the advantage of 2) is that I wouldn't have one half or more
>>> of processes idling and I could overlap the solves of both subpc in the
>>> PCCOMPOSITE.
>>> I’m attaching the -log_view for both runs (I trimmed some options).
>>> Thanks for your help,
>>> Pierre
>>> > Best regards,
>>> > Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180727/e9ca1ca4/attachment.html>
