[petsc-dev] Bad scaling of GAMG in FieldSplit
    Junchao Zhang
    jczhang at mcs.anl.gov
    Thu Jul 26 09:26:07 CDT 2018
Could you send the full -log_view output?
--Junchao Zhang
On Thu, Jul 26, 2018 at 8:39 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
wrote:
> Hello,
> I’m using GAMG on a shifted Laplacian with these options:
> -st_fieldsplit_pressure_ksp_type preonly
> -st_fieldsplit_pressure_pc_composite_type additive
> -st_fieldsplit_pressure_pc_type composite
> -st_fieldsplit_pressure_sub_0_ksp_pc_type jacobi
> -st_fieldsplit_pressure_sub_0_pc_type ksp
> -st_fieldsplit_pressure_sub_1_ksp_pc_gamg_square_graph 10
> -st_fieldsplit_pressure_sub_1_ksp_pc_type gamg
> -st_fieldsplit_pressure_sub_1_pc_type ksp
> and I end up with the following logs on 512 (top) and 2048 (bottom)
> processes:
> MatMult          1577790 1.0 3.1967e+03 1.2 4.48e+12 1.6 7.6e+09 5.6e+03
> 0.0e+00  7 71 75 63  0   7 71 75 63  0 650501
> MatMultAdd        204786 1.0 1.3412e+02 5.5 1.50e+10 1.7 5.5e+08 2.7e+02
> 0.0e+00  0  0  5  0  0   0  0  5  0  0 50762
> MatMultTranspose  204786 1.0 4.6790e+01 4.3 1.50e+10 1.7 5.5e+08 2.7e+02
> 0.0e+00  0  0  5  0  0   0  0  5  0  0 145505
> KSPSolve_FS_3       7286 1.0 7.5506e+02 1.0 9.14e+11 1.8 7.3e+09 1.5e+03
> 2.6e+05  2 14 71 16 34   2 14 71 16 34 539009
> MatMult          1778795 1.0 3.5511e+03 4.1 1.46e+12 1.9 4.0e+10 2.4e+03
> 0.0e+00  7 66 75 61  0   7 66 75 61  0 728371
> MatMultAdd        222360 1.0 2.5904e+0348.0 4.31e+09 1.9 2.4e+09 1.3e+02
> 0.0e+00 14  0  4  0  0  14  0  4  0  0  2872
> MatMultTranspose  222360 1.0 1.8736e+03421.8 4.31e+09 1.9 2.4e+09 1.3e+02
> 0.0e+00  0  0  4  0  0   0  0  4  0  0  3970
> KSPSolve_FS_3       7412 1.0 2.8939e+03 1.0 2.66e+11 2.1 3.5e+10 6.1e+02
> 2.7e+05 17 11 67 14 28  17 11 67 14 28 148175
> MatMultAdd and MatMultTranspose (performed by GAMG) somehow ruin the
> scalability of the overall solver. The pressure space “only” has 3M
> unknowns so I’m guessing that’s why GAMG is having a hard time strong
> scaling. For the other fields, the matrix is somehow distributed nicely,
> i.e., I don’t want to change the overall distribution of the matrix.
> Do you have any suggestion to improve the performance of GAMG in that
> scenario? I had two ideas in mind but please correct me if I’m wrong or if
> this is not doable:
> 1) before setting up GAMG, first use a PCTELESCOPE to avoid having too
> many processes work on this small problem
> 2) have the sub_0_ and the sub_1_ work on two different nonoverlapping
> communicators of size PETSC_COMM_WORLD/2, do the solve concurrently, and
> then sum the solutions (only worth doing because of -pc_composite_type
> additive). I have no idea if this easily doable with PETSc command line
> arguments
> Thanks in advance for your guidance,
> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180726/67cd4418/attachment.html>
