[petsc-dev] could we let "make -j N" work for PETSc and external packages?
    Jed Brown
    jed at jedbrown.org
    Tue Jul 24 17:02:18 CDT 2018
Fande Kong <Fande.Kong at inl.gov> writes:
> Thanks, Jed and Satish,
> But "make -j N" does not change anything when compiling petsc.
> If I do something like: "make -j whatever". Then I always get:
> Using MAKEFLAGS: -j8 -l36.0 w
> It looks like PETSc always uses "-j something" that we can not change using the command-line.
> Is it a bug?
https://bitbucket.org/petsc/petsc/pull-requests/873/make-allow-j-options-in-top-level-makefile/diff
