[petsc-dev] PETSc goes Jenkins
    Jed Brown
    jed at jedbrown.org
    Fri Jul 20 23:07:55 CDT 2018
Karl Rupp <rupp at iue.tuwien.ac.at> writes:
> Hi Patrick,
>> Once tuning is complete, how is one intended to interpret the nice green
>> check marks? "The library compiles" or "All the tests passed"?
> So far the green checkmark essentially means "The library compiles". We
> are working towards "All the tests passed", but that requires some more
> tinkering in processing test output. That is, we need to extract
> information about failed tests and present that in a prominent way.
Our tests produce TAP.
https://wiki.jenkins.io/display/JENKINS/TAP+Plugin
