[petsc-dev] Could we replace SNESTestJacobian() in maint with that in master?
    Kong, Fande
    fande.kong at inl.gov
    Wed Jul 18 17:54:49 CDT 2018
To explain me a little better, I added a PR at
https://bitbucket.org/petsc/petsc/pull-requests/1040/fixed-snestestjacobian-in-maint/diff
I just simply copied SNESTestJacobian() in master to maint.
This patch fixed the issues we had in MOOSE.
Fande,
On Wed, Jul 18, 2018 at 4:47 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> Hi Karl,
> On Wed, Jul 18, 2018 at 4:02 PM, Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
>> Hi Fande,
>> It looks like SNESTestJacobian() in master is more reliable than that in
>>> maint.  Especially, the petsc options name is changed. For example, from
>>> "-snes_test_jacobian_display" to "-snes_test_jacobian_view".
>>> There are some MOOSE tests that fail with the maint version of
>>> SNESTestJacobian(), but they are just fine with the master version of
>>> SNESTestJacobian().
>> are you able to provide us with a standalone test that exposes the
>> problem so that we can fix it?
> I do not think it is a good idea to fix the thing in maint that has  been
> already fixed in master.  It is really hard to just copy the whole SNESTestJacobian()
> in maint to master??  I could do a PR, if you guys agree with this.
> Fande,
>> What is the release date for PETSc-3.10.x? I could just skip PETSc-3.9.x,
>>> if we would have the next release soon.
>> Late September 2018.
>> Best regards,
>> Karli
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180718/68ff9ac2/attachment.html>
