[petsc-dev] Chombo-Crunch as bench mark for PETSc with hybrid MPI/OpenMP
Smith, Barry F.
bsmith at mcs.anl.gov
Sat Jul 7 19:41:15 CDT 2018
Mark,
Is there any chance the Chombo-Crunch team could cook up a portable good sized example (but not too large), preferably with a run time parameter that determines the problem size, example that anyone could use as a benchmark for "adding OpenMP" to PETSc. This way we could have real numbers as we compare different approaches; for example calling MKL vs putting in a few OpenMP pragmas in the source code.
Thanks
Barry
For size I'm thinking of running on a handful of cores up to a few nodes of KNL.
