[petsc-dev] titan
Mark Adams mfadams at lbl.gov
Sat Jul 7 07:09:01 CDT 2018
On Fri, Jul 6, 2018 at 7:30 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Mark,
>     We should get your arch-titan-opt64idx-pgi.py into the master branch
> of PETSc in config/examples if there is not something equivalent there
> already.
I do not recall if I did anything special for Titan, aprun and compilers is
about all I see. maybe '--known-mpi-shared-libraries=1' was added,
otherwise it looks like a cloned config file. I did comment out cmake after
learning that I could load the module. Maybe make a note in this file as I
did here
#!/usr/bin/env python
if __name__ == '__main__':
  import sys
  import os
  sys.path.insert(0, os.path.abspath('config'))
  import configure
  configure_options = [
  '--COPTFLAGS=-fast',
  '--CXXOPTFLAGS=-fast',
  '--FOPTFLAGS=-fast',
  '--with-ssl=0',
  '--with-batch=0',
  '--with-mpiexec=aprun',
  '--download-fblaslapack',
#    '--download-superlu',
    '--with-openmp',
    '--prefix=/ccs/proj/env003/petscv3.9-titan-opt64-pgi',
    '--download-hypre',
    '--download-metis',
    '--with-hwloc=0',
    '--download-parmetis',
#    '--download-cmake', // use: module load cmake
    '--with-cc=cc',
#    '--with-clib-autodetect=0',
    '--with-cxx=CC',
#    '--with-cxxlib-autodetect=0',
    '--with-fc=ftn',
#    '--with-fortranlib-autodetect=0',
    '--with-shared-libraries=0',
    '--known-mpi-shared-libraries=1',
    '--with-x=0',
    '--with-64-bit-indices=1',
    '--with-debugging=0',
    'PETSC_ARCH=arch-titan-opt64-pgi',
  configure.petsc_configure(configure_options)
>     Also is the .py file different for summit? I would expect so, we
> should get that into config/examples also.
And and same with summit, this still has cmake, which I assume could be
removed if you load the cmake module:
  import sys
  import os
  import configure
  '--COPTFLAGS=-g',
  '--CXXOPTFLAGS=-g',
  '--FOPTFLAGS=-g',
  '--with-ssl=0',
  '--with-batch=0',
#  '--with-mpiexec=aprun',
#    '--with-threadcomm',
#    '--with-pthreadclasses',
#    '--with-openmp',
    '--prefix=/ccs/proj/env003/petscv3.7-dbg64-summit-pgi',
#    '--download-hypre',
    '--download-metis',
    '--with-hwloc=0',
    '--download-cmake',
    '--with-cc=mpicc',
#    '--with-fc=0',
#    '--with-cxx=mpiCC',
    '--with-fc=mpif90',
    '--with-x=0',
    '--with-64-bit-indices',
    '--with-debugging=1',
    'PETSC_ARCH=arch-summit-dbg64-pgi',
>    Thanks
>    Barry
> > On Jul 6, 2018, at 6:19 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > Todd, I've been building PETSc on Titan and SUMMIT for users. cray-petsc
> has been hosed for a while. I put my most recent configure file in:
> > /ccs/proj/env003/arch-titan-opt64idx-pgi.py
> > This is a public space. My builds are here also. You run with, for
> instance,
> > make PETSC_DIR=/ccs/proj/env003/petscv3.9-opt64-pgi PETSC_ARCH=""
> > There are several other builds in there that you can use. I now see that
> I don't have the machine name in the directory name, yuck. But this and a
> v3.7 version are recent and work (on Titan).
> > Mark
> > On Fri, Jul 6, 2018 at 6:47 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >    I know Mark Adams has tried recently; without limited success.
> >    As always the big problem is facilities removing accounts, such as
> Satish's, so testing gets difficult.
> >    But yes, we want to support Titan so have users send
> configure.log/make.log to petsc-maint at mcs.anl.gov
> >    Barry
> > > On Jul 6, 2018, at 12:45 PM, Munson, Todd <tmunson at mcs.anl.gov> wrote:
> > > Barry,
> > > Have you tested petsc compilation on titan?  Is there a config example
> > > for that machine?
> > > Apparently titan died and when they brought it back up, the petsc
> install
> > > was fracked, so some ORNL users are trying to compile petsc locally
> > > rather than wait for the facilities people.
> > > Thanks, Todd
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180707/3e739435/attachment-0001.html>
