[petsc-dev] Remove legacy tests?
Smith, Barry F.
bsmith at mcs.anl.gov
Sat Jul 7 19:31:32 CDT 2018
I'm fine with stripping out as much of the old test stuff as reasonably possible.
Barry
> On Jul 5, 2018, at 8:36 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>> On Jul 5, 2018, at 5:36 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> When can we delete the legacy test system? Are we currently using it
>>> anywhere?
>> Make test currently requires the test include file
> Surely this indirection and logging isn't needed in all the
> */examples/tutorials/makefile.
> TESTMODE = testexamples
> ALLTESTS_CHECK_FAILURES = no
> ALLTESTS_MAKEFILE = gmakefile.test
> alltests:
> -@${RM} -rf ${PETSC_ARCH}/lib/petsc/conf/alltests.log alltests.log
> + at if [ -f ${PETSC_DIR}/share/petsc/examples/gmakefile.test ] ; then \
> ALLTESTS_MAKEFILE=${PETSC_DIR}/share/petsc/examples/gmakefile.test ; \
> ALLTESTSLOG=alltests.log ;\
> else \
> ALLTESTS_MAKEFILE=gmakefile.test; \
> ALLTESTSLOG=${PETSC_ARCH}/lib/petsc/conf/alltests.log ;\
> ln -s $${ALLTESTSLOG} alltests.log ;\
> fi; \
> ${OMAKE} allgtest ALLTESTS_MAKEFILE=$${ALLTESTS_MAKEFILE} PETSC_ARCH=${PETSC_ARCH} PETSC_DIR=${PETSC_DIR} MPIEXEC="${MPIEXEC}" DATAFILESPATH=${DATAFILESPATH} 2>&1 | tee $${ALLTESTSLOG};\
> if [ x${ALLTESTS_CHECK_FAILURES} = xyes -a ${PETSC_PRECISION} != single ]; then \
> cat $${ALLTESTSLOG} | egrep '(^not ok|not remade because of errors|^# No tests run)' | wc -l | grep '^[ ]*0$$' > /dev/null; \
> fi;
> allgtest-tap:
> + at MAKEFLAGS="-j$(MAKE_TEST_NP) -l$(MAKE_LOAD) $(MAKEFLAGS)" ${OMAKE} -f gmakefile.test test V=0
> allgtest:
> + at MAKEFLAGS="-j$(MAKE_TEST_NP) -l$(MAKE_LOAD) $(MAKEFLAGS)" ${OMAKE} -k -f ${ALLTESTS_MAKEFILE} test V=0 2>&1 | egrep -v '^(ok [^#]*(# SKIP|# TODO|$$)|[A-Za-z][A-Za-z0-9_]*\.(c|F|cxx|F90).$$)'
> We could use static pattern rules of the form
> $(EXAMPLESC) : % : %.c
> and add them to lib/petsc/conf/rules. It isn't really for testing at
> this point, just for one-off building.
