[petsc-dev] Remove legacy tests?
    Jed Brown
    jed at jedbrown.org
    Thu Jul  5 20:36:01 CDT 2018
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>> On Jul 5, 2018, at 5:36 PM, Jed Brown <jed at jedbrown.org> wrote:
>> When can we delete the legacy test system?  Are we currently using it
>> anywhere?
>   Make test currently requires the test include file
Surely this indirection and logging isn't needed in all the
*/examples/tutorials/makefile.
TESTMODE = testexamples
ALLTESTS_CHECK_FAILURES = no
ALLTESTS_MAKEFILE = gmakefile.test
alltests:
        -@${RM} -rf ${PETSC_ARCH}/lib/petsc/conf/alltests.log alltests.log
        + at if [ -f ${PETSC_DIR}/share/petsc/examples/gmakefile.test ] ; then \
            ALLTESTS_MAKEFILE=${PETSC_DIR}/share/petsc/examples/gmakefile.test ; \
            ALLTESTSLOG=alltests.log ;\
          else \
            ALLTESTS_MAKEFILE=gmakefile.test; \
            ALLTESTSLOG=${PETSC_ARCH}/lib/petsc/conf/alltests.log ;\
            ln -s $${ALLTESTSLOG} alltests.log ;\
          fi; \
          ${OMAKE} allgtest ALLTESTS_MAKEFILE=$${ALLTESTS_MAKEFILE} PETSC_ARCH=${PETSC_ARCH} PETSC_DIR=${PETSC_DIR} MPIEXEC="${MPIEXEC}" DATAFILESPATH=${DATAFILESPATH} 2>&1 | tee $${ALLTESTSLOG};\
          if [ x${ALLTESTS_CHECK_FAILURES} = xyes -a ${PETSC_PRECISION} != single ]; then \
            cat $${ALLTESTSLOG} | egrep '(^not ok|not remade because of errors|^# No tests run)' | wc -l | grep '^[ ]*0$$' > /dev/null; \
          fi;
allgtest-tap:
        + at MAKEFLAGS="-j$(MAKE_TEST_NP) -l$(MAKE_LOAD) $(MAKEFLAGS)" ${OMAKE} -f gmakefile.test test V=0
allgtest:
        + at MAKEFLAGS="-j$(MAKE_TEST_NP) -l$(MAKE_LOAD) $(MAKEFLAGS)" ${OMAKE} -k -f ${ALLTESTS_MAKEFILE} test V=0 2>&1 | egrep -v '^(ok [^#]*(# SKIP|# TODO|$$)|[A-Za-z][A-Za-z0-9_]*\.(c|F|cxx|F90).$$)'
We could use static pattern rules of the form
  $(EXAMPLESC) : % : %.c
and add them to lib/petsc/conf/rules.  It isn't really for testing at
this point, just for one-off building.
