[petsc-dev] Error compiling PETSc on Windows
Hector E Barrios Molano hectorb at utexas.edu
Sat Jul 7 16:40:03 CDT 2018
Thanks Barry and Satish for your answers.
I installed the correct version of hypre. Also, I changed the paths to
short dos paths as Satish suggested. Now PETSc compiles without problems
and the tests are ok.
Regarding Satish notes:
I had to include -LIBS because otherwise the configure script stops
while testing blas-lapack with the following error:
TESTING: checkLib from
config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:114)*******************************************************************************
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
You set a value for --with-blaslapack-lib=<lib>, but
['-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~1/windows/mkl/lib/intel64',
'mkl_intel_lp64.lib', 'mkl_core.lib', 'mkl_intel_thread.lib'] cannot be used
Do I need to turn on the MKL sparse functionality? what is the
difference between MKL_SPARSE, MKL_SPARSE_OPTIMIZE and MKL_SPARSE_SP2M
in the configure options?
Why is better to use sequential MKL? Is it possible to use a hybrid MPI
- OpenMP approach? for example MPI for internode communication and
OpenMP for intranode computation? In that case would it be good to use
threaded MKL + MPI?
Hector
On 07/05/2018 08:54 PM, Satish Balay wrote:
> A few additional notes:
> On Thu, 5 Jul 2018, Satish Balay wrote:
>> Using configure Options: --prefix=/cygdrive/c/installed/petsc_git-intel-debug/ --PETSC_DIR=/cygdrive/c/sources/petsc --PETSC_ARCH=windows-intel-debug --with-cc="win32fe cl" --with-fc="win32fe ifort" --with-mpi-include="[/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mpi/intel64/include]" --with-mpi-lib="[/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mpi/intel64/lib/release_mt/impi.lib]"
>>   --with-openmp=1
> I don't think this option does anything [on windows]
>> --with-parmetis-lib=/cygdrive/c/installed/parmetis/lib/parmetis.lib --with-parmetis-include=/cygdrive/c/installed/parmetis/include --with-metis-lib=/cygdrive/c/installed/parmetis/lib/metis.lib --with-metis-include=/cygdrive/c/installed/parmetis/include --with-zoltan-include=/cygdrive/c/installed/zoltan/include --with-zoltan-lib=/cygdrive/c/installed/zoltan/lib/zoltan.lib --with-hypre-include=/cygdrive/c/installed/hypre/include --with-hypre-lib=/cygdrive/c/installed/hypre/lib/HYPRE.lib --with-blaslapack-lib="[/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_intel_thread.lib]"
>>   --with-scalapack-include="/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/include" --with-scalapack-lib="[/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_blacs_intelmpi_lp64.lib]"
> PETSc does not use scalapack or blacs. They are dependencies for MUMPS [which petsc has an interface to]
>> --with-shared-libraries=0
>> -LIBS=""/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_intel_lp64.lib" "/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_intel_thread.lib" "/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64//mkl_core.lib" "/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_scalapack_lp64.lib" "/cygdrive/c/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018/windows/mkl/lib/intel64/mkl_blacs_intelmpi_lp64.lib" libiomp5md.lib"
> I'm not sure why you are having to respecify MKL via LIBS option.
> Also with PETSc MPI usage - its best to use sequential MKL - and not threaded MKL - for eg:
>> --with-blaslapack-lib='-L/cygdrive/c/PROGRA~2/INTELS~1/COMPIL~2/windows/mkl/lib/intel64 mkl_intel_lp64_dll.lib mkl_sequential_dll.lib mkl_core_dll.lib'
>>> mhypre.c
>>> C:\sources\petsc\src\mat\impls\hypre\mhypre.c(1453): warning C4002: too many actual parameters for macro 'hypre_TFree'
> You can switch to the compatible version of hypre - or fix revert the code change..
> https://bitbucket.org/petsc/petsc/commits/e6de09342ce9c4562cc062ff2c1bac4bd956bda0
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180707/75c406e1/attachment.html>
