[petsc-dev] Adding p4est to nightly tests
    Tobin Isaac
    tisaac at cc.gatech.edu
    Wed Jul  4 13:05:04 CDT 2018
Understood, I'll get them under control and then ping you when I think it's ready.
On July 4, 2018 1:16:09 PM EDT, Satish Balay <balay at mcs.anl.gov> wrote:
>Will need to fix these issues before I can add the tests. I just tried
>on one box - and get the
>attached errors.
>Satish
>On Sun, 1 Jul 2018, Lisandro Dalcin wrote:
>> And what about adding pragmatic? Right now I'm getting this failure
>in master.
>> make -f gmakefile test search=snes_tutorials-ex12_mg_newton_coarse_2
>> Use "/usr/bin/gmake V=1" to see verbose compile lines,
>"/usr/bin/gmake
>> V=0" to suppress.
>>           CC arch-packages/tests/snes/examples/tutorials/ex12.o
>>      CLINKER arch-packages/tests/snes/examples/tutorials/ex12
>>         TEST
>arch-packages/tests/counts/snes_tutorials-ex12_mg_newton_coarse_2.counts
>> not ok snes_tutorials-ex12_mg_newton_coarse_2
>> # [0]PETSC ERROR: --------------------- Error Message
>> # [0]PETSC ERROR: Petsc has generated inconsistent data
>> # [0]PETSC ERROR: Coarse dof 230 maps to both 79 and 674
>> # [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> # [0]PETSC ERROR: Petsc Development GIT revision:
>> v3.9.2-825-g3a11c7608d  GIT Date: 2018-07-01 06:15:09 +0200
>> # [0]PETSC ERROR: ../ex12 on a arch-packages named kw14821 by dalcinl
>> Sun Jul  1 12:54:44 2018
>> # [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-packages
>> --download-chaco --download-ctetgen --download-eigen
>> --download-exodusii --download-hdf5 --download-metis
>--download-netcdf
>> --download-p4est --download-parmetis --download-pnetcdf
>> --download-pragmatic --download-ptscotch --download-triangle
>> --download-yaml --with-gmp --with-mpfr
>> # [0]PETSC ERROR: #1 DMPlexComputeInjectorFEM() line 2297 in
>> /home/devel/petsc/dev/src/dm/impls/plex/plexfem.c
>> # [0]PETSC ERROR: #2 DMCreateInjection_Plex() line 6664 in
>> /home/devel/petsc/dev/src/dm/impls/plex/plex.c
>> # [0]PETSC ERROR: #3 DMCreateInjection() line 1169 in
>> /home/devel/petsc/dev/src/dm/interface/dm.c
>> # [0]PETSC ERROR: #4 PCSetUp_MG() line 691 in
>> /home/devel/petsc/dev/src/ksp/pc/impls/mg/mg.c
>> # [0]PETSC ERROR: #5 PCSetUp() line 932 in
>> /home/devel/petsc/dev/src/ksp/pc/interface/precon.c
>> # [0]PETSC ERROR: #6 KSPSetUp() line 381 in
>> /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c
>> # [0]PETSC ERROR: #7 KSPSolve() line 612 in
>> # [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in
>> /home/devel/petsc/dev/src/snes/impls/ls/ls.c
>> # [0]PETSC ERROR: #9 SNESSolve() line 4350 in
>> /home/devel/petsc/dev/src/snes/interface/snes.c
>> # [0]PETSC ERROR: #10 main() line 1065 in
>> /home/devel/petsc/dev/src/snes/examples/tutorials/ex12.c
>> # [0]PETSC ERROR: PETSc Option Table entries:
>> # [0]PETSC ERROR: -dm_coarsen_hierarchy 5
>> # [0]PETSC ERROR: -dm_plex_hash_location
>> # [0]PETSC ERROR: -dm_plex_remesh_bd
>> # [0]PETSC ERROR: -dm_plex_separate_marker
>> # [0]PETSC ERROR: -dm_refine 5
>> # [0]PETSC ERROR: -dm_view
>> # [0]PETSC ERROR: -interpolate 1
>> # [0]PETSC ERROR: -ksp_monitor_true_residual
>> # [0]PETSC ERROR: -ksp_rtol 1.0e-12
>> # [0]PETSC ERROR: -ksp_type richardson
>> # [0]PETSC ERROR: -ksp_view
>> # [0]PETSC ERROR: -mg_levels_ksp_max_it 2
>> # [0]PETSC ERROR: -mg_levels_ksp_monitor_true_residual
>> # [0]PETSC ERROR: -pc_mg_levels 3
>> # [0]PETSC ERROR: -pc_type mg
>> # [0]PETSC ERROR: -petscspace_order 1
>> # [0]PETSC ERROR: -run_type full
>> # [0]PETSC ERROR: -snes_converged_reason ::ascii_info_detail
>> # [0]PETSC ERROR: -snes_monitor
>> # [0]PETSC ERROR: ----------------End of Error Message -------send
>> entire error message to petsc-maint at mcs.anl.gov----------
>> # application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
>> ok snes_tutorials-ex12_mg_newton_coarse_2 # SKIP Command failed so no
>diff
>> #   Summary
>> # FAILED snes_tutorials-ex12_mg_newton_coarse_2
>> # success 0/1 tests (0.0%)
>> # failed 1/1 tests (100.0%)
>> # todo 0/1 tests (0.0%)
>> # skip 0/1 tests (0.0%)
>> # Wall clock time for tests: 42 sec
>> # Approximate CPU time (not incl. build time): 0.0 sec
>> # To rerun failed tests:
>> #     /usr/bin/gmake -f gmakefile test
>> search='snes_tutorials-ex12_mg_newton_coarse_2'
>> # Timing summary:
>> #   snes_tutorials-ex12_mg_newton_coarse_2: 0.00 sec
>> On Sun, 1 Jul 2018 at 01:07, Stefano Zampini
><stefano.zampini at gmail.com> wrote:
>> > Satish,
>> > when you have time can you add p4est to some of the archs we tests
>nightly?
>> > Matt and/or Toby, is there any reason why p4est is not under the
>testsuite?
>> > Thanks,
>> > Stefano
