[petsc-dev] Adding p4est to nightly tests
Wed Jul 4 12:16:09 CDT 2018
Will need to fix these issues before I can add the tests. I just tried on one box - and get the
attached errors.
Satish
On Sun, 1 Jul 2018, Lisandro Dalcin wrote:
> And what about adding pragmatic? Right now I'm getting this failure in master.
> make -f gmakefile test search=snes_tutorials-ex12_mg_newton_coarse_2
> Use "/usr/bin/gmake V=1" to see verbose compile lines, "/usr/bin/gmake
> V=0" to suppress.
>           CC arch-packages/tests/snes/examples/tutorials/ex12.o
>      CLINKER arch-packages/tests/snes/examples/tutorials/ex12
>         TEST arch-packages/tests/counts/snes_tutorials-ex12_mg_newton_coarse_2.counts
> not ok snes_tutorials-ex12_mg_newton_coarse_2
> # [0]PETSC ERROR: --------------------- Error Message
> # [0]PETSC ERROR: Petsc has generated inconsistent data
> # [0]PETSC ERROR: Coarse dof 230 maps to both 79 and 674
> # [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> # [0]PETSC ERROR: Petsc Development GIT revision:
> v3.9.2-825-g3a11c7608d  GIT Date: 2018-07-01 06:15:09 +0200
> # [0]PETSC ERROR: ../ex12 on a arch-packages named kw14821 by dalcinl
> Sun Jul  1 12:54:44 2018
> # [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-packages
> --download-chaco --download-ctetgen --download-eigen
> --download-exodusii --download-hdf5 --download-metis --download-netcdf
> --download-p4est --download-parmetis --download-pnetcdf
> --download-pragmatic --download-ptscotch --download-triangle
> --download-yaml --with-gmp --with-mpfr
> # [0]PETSC ERROR: #1 DMPlexComputeInjectorFEM() line 2297 in
> /home/devel/petsc/dev/src/dm/impls/plex/plexfem.c
> # [0]PETSC ERROR: #2 DMCreateInjection_Plex() line 6664 in
> /home/devel/petsc/dev/src/dm/impls/plex/plex.c
> # [0]PETSC ERROR: #3 DMCreateInjection() line 1169 in
> /home/devel/petsc/dev/src/dm/interface/dm.c
> # [0]PETSC ERROR: #4 PCSetUp_MG() line 691 in
> /home/devel/petsc/dev/src/ksp/pc/impls/mg/mg.c
> # [0]PETSC ERROR: #5 PCSetUp() line 932 in
> /home/devel/petsc/dev/src/ksp/pc/interface/precon.c
> # [0]PETSC ERROR: #6 KSPSetUp() line 381 in
> /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c
> # [0]PETSC ERROR: #7 KSPSolve() line 612 in
> # [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in
> /home/devel/petsc/dev/src/snes/impls/ls/ls.c
> # [0]PETSC ERROR: #9 SNESSolve() line 4350 in
> /home/devel/petsc/dev/src/snes/interface/snes.c
> # [0]PETSC ERROR: #10 main() line 1065 in
> /home/devel/petsc/dev/src/snes/examples/tutorials/ex12.c
> # [0]PETSC ERROR: PETSc Option Table entries:
> # [0]PETSC ERROR: -dm_coarsen_hierarchy 5
> # [0]PETSC ERROR: -dm_plex_hash_location
> # [0]PETSC ERROR: -dm_plex_remesh_bd
> # [0]PETSC ERROR: -dm_plex_separate_marker
> # [0]PETSC ERROR: -dm_refine 5
> # [0]PETSC ERROR: -dm_view
> # [0]PETSC ERROR: -interpolate 1
> # [0]PETSC ERROR: -ksp_monitor_true_residual
> # [0]PETSC ERROR: -ksp_rtol 1.0e-12
> # [0]PETSC ERROR: -ksp_type richardson
> # [0]PETSC ERROR: -ksp_view
> # [0]PETSC ERROR: -mg_levels_ksp_max_it 2
> # [0]PETSC ERROR: -mg_levels_ksp_monitor_true_residual
> # [0]PETSC ERROR: -pc_mg_levels 3
> # [0]PETSC ERROR: -pc_type mg
> # [0]PETSC ERROR: -petscspace_order 1
> # [0]PETSC ERROR: -run_type full
> # [0]PETSC ERROR: -snes_converged_reason ::ascii_info_detail
> # [0]PETSC ERROR: -snes_monitor
> # [0]PETSC ERROR: ----------------End of Error Message -------send
> entire error message to petsc-maint at mcs.anl.gov----------
> # application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
> ok snes_tutorials-ex12_mg_newton_coarse_2 # SKIP Command failed so no diff
> #   Summary
> # FAILED snes_tutorials-ex12_mg_newton_coarse_2
> # success 0/1 tests (0.0%)
> # failed 1/1 tests (100.0%)
> # todo 0/1 tests (0.0%)
> # skip 0/1 tests (0.0%)
> # Wall clock time for tests: 42 sec
> # Approximate CPU time (not incl. build time): 0.0 sec
> # To rerun failed tests:
> #     /usr/bin/gmake -f gmakefile test
> search='snes_tutorials-ex12_mg_newton_coarse_2'
> # Timing summary:
> #   snes_tutorials-ex12_mg_newton_coarse_2: 0.00 sec
> On Sun, 1 Jul 2018 at 01:07, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> > Satish,
> > when you have time can you add p4est to some of the archs we tests nightly?
> > Matt and/or Toby, is there any reason why p4est is not under the testsuite?
> > Thanks,
> > Stefano
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180704/46bfa4fd/attachment-0001.ksh>
