[petsc-dev] GAMG error with MKL
    Mark Adams
    mfadams at lbl.gov
    Tue Jul  3 08:28:34 CDT 2018
GAMG drills into AIJ data structures and will need to be fixed up to work
with MKL matrices, I guess, but it is failing now from a logic error.
This example works with one processor but fails with 2 (appended). The code
looks like this:
    ierr =
PetscObjectBaseTypeCompare((PetscObject)Amat,MATSEQAIJ,&isseqaij);CHKERRQ(ierr);
    ierr =
PetscObjectBaseTypeCompare((PetscObject)Amat,MATMPIAIJ,&ismpiaij);CHKERRQ(ierr);
    if (isseqaij) {
    } else if (ismpiaij) {
      ierr = MatMPIAIJGetSeqAIJ(Amat,&Daij,&Oaij,&garray);CHKERRQ(ierr);
The failure below is from this call to MatMPIAIJGetSeqAIJ, on this line:
ierr = PetscObjectTypeCompare((PetscObject)A,MATMPIAIJ,&flg);CHKERRQ(ierr);
The difference is PetscObjectTypeCompare vs PetscObject*Base*TypeCompare.
GAMG could use PetscObjectTypeCompare or MatMPIAIJGetSeqAIJ could use
PetscObject*Base*TypeCompare ...
srun -n 2 ./ex19 -pc_type gamg -snes_monitor_short -ksp_monitor_short
lid velocity = 0.0625, prandtl # = 1., grashof # = 1.
  0 SNES Function norm 0.239155
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: This function requires a MATMPIAIJ matrix as input
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.9.2-825-g3a11c7608d  GIT
Date: 2018-07-01 06:15:09 +0200
[0]PETSC ERROR:
/global/u2/m/madams/petsc_install/petsc/src/snes/examples/tutorials/./ex19
on a  named nid02516 by madams Tue Jul  3 04:58:13 2018
[0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
--known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
--known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
--known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
--known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
--known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
--known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
--known-mpi-c-double-complex=1 --known-mklspblas-supports-zero-based=0
--known-has-attribute-aligned=1 --with-cc=cc --with-cxx=CC --with-fc=ftn
COPTFLAGS="  -g -O1 -mkl -static-intel" CXXOPTFLAGS="-g -O1 -mkl
-static-intel" FOPTFLAGS="  -g -O1 -mkl -static-intel" --download-metis=1
--with-hypre-dir=/global/homes/m/madams/tmp/hypre32-2.14.0
--download-parmetis=1
LIBS="-L/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/lib/intel64
-lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread"
--with-blaslapack-include=/opt/intel/compilers_and_libraries_2018.1.163/linux/mkl/include
--with-debugging=0 --with-mpiexec=srun --with-batch=1
--known-mpi-shared-libraries=1 --known-64-bit-blas-indices=0
--with-64-bit-indices=0 PETSC_ARCH=arch-cori-knl-opt-intel-omp
--with-openmp=1 --download-p4est=0 --with-x=0
--prefix=/global/homes/m/madams/petsc_install/petsc-cori-knl-opt-intel-omp
PETSC_DIR=/global/homes/m/madams/petsc_install/petsc
[0]PETSC ERROR: #1 MatMPIAIJGetSeqAIJ() line 4328 in
/global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: #2 PCGAMGCreateGraph() line 118 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/util.c
[0]PETSC ERROR: #3 PCGAMGGraph_AGG() line 832 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/agg.c
[0]PETSC ERROR: #4 PCSetUp_GAMG() line 517 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/gamg.c
[0]PETSC ERROR: #5 PCSetUp() line 932 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSPSetUp() line 381 in
/global/u2/m/madams/petsc_install/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #7 KSPSolve() line 612 in
[0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in
/global/u2/m/madams/petsc_install/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #9 SNESSolve() line 4350 in
/global/u2/m/madams/petsc_install/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #10 main() line 161 in
/global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials/ex19.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -ksp_monitor_short
[0]PETSC ERROR: -mat_type aijmkl
[0]PETSC ERROR: -options_left
[0]PETSC ERROR: -pc_type gamg
[0]PETSC ERROR: -snes_monitor_short
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180703/ce1ab0de/attachment.html>
