[petsc-dev] GAMG and custom MatMults in smoothers
Matthew Knepley
knepley at gmail.com
Mon Jul 2 10:32:52 CDT 2018
On Mon, Jul 2, 2018 at 10:19 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> 2. 7. 2018 v 16:38, Matthew Knepley <knepley at gmail.com>:
> On Mon, Jul 2, 2018 at 9:33 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
> wrote:
>> 2. 7. 2018 v 15:50, Matthew Knepley <knepley at gmail.com>:
>> On Mon, Jul 2, 2018 at 8:28 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>> wrote:
>>> 2. 7. 2018 v 15:05, Matthew Knepley <knepley at gmail.com>:
>>> On Mon, Jul 2, 2018 at 7:54 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>> wrote:
>>>> 2. 7. 2018 v 14:48, Matthew Knepley <knepley at gmail.com>:
>>>> On Mon, Jul 2, 2018 at 3:48 AM Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>>> wrote:
>>>>> Barry wrote:
>>>>> This could get ugly real fast, for example, for vector operations,
>>>>> there may be dozens of named vectors and each one gets its own logging?
>>>>> You'd have to make sure that only the objects you care about get named, is
>>>>> that possible?
>>>>> I don't know if there is a good solution within the PETSc logging
>>>>> infrastructure to get what you want but maybe what you propose is the best
>>>>> possible.
>>>>> As I suggest, this behavior would be only triggered by a specific
>>>>> option.
>>>>> I think there are actually 4 strings which could be used as an event
>>>>> name suffix in log view:
>>>>> 1) name
>>>>> 2) prefix
>>>>> 3) type
>>>>> 4) custom string (set by something like PetscObjectSetLogViewSuffix)
>>>>> I think the best would be to let user choose by offering
>>>>> -log_view_by_{name,prefix,type,suffix}.
>>>>> For example, with -log_view_by_prefix, you could readily distinguish
>>>>> PCTelescope outer and inner apply, because you would see a separate
>>>>> "PCApply (telescope_)" event.
>>>>> With -log_view_by_type, you would see PCApply (telescope).
>>>>> I think this would be useful because the current class-wide events
>>>>> like MatMult or PCApply aggregate very different operations from which some
>>>>> are for free and some form hotspots.
>>>>> Stefano wrote:
>>>>> The issue with this sort of “dynamic” logging is that now PETSc
>>>>> requires PetscLogEvent created during the registration of the class, so
>>>>> that all the ranks in PETSC_COMM_WORLD have the same events registered.
>>>>> What you propose is not generally supported for this specific reason.
>>>>> Your “log_name” may work if users register their own classes (with
>>>>> their own LogEvents created properly), and currently we don’t have support
>>>>> (maybe I’m wrong) to add an “InitializePackage” method for the users’
>>>>> registered classes.
>>>>> I don't agree. What I suggest is basically an ability to allow
>>>>> automatically created object-wise events, so it _can't_ be managed during
>>>>> the class registration. In presence of respective option, the event would
>>>>> be created during PetscLogEventBegin by taking the class-wide event's name,
>>>>> concatenating the suffix and registering a new event. The event id would be
>>>>> stored in the PetscObject structure.
>>>>> Matt wrote:
>>>>> As people have pointed out, this would not work well for Events.
>>>>> However, this is exactly what stages are for.
>>>>> Use separate stages for the different types of MatMult. I did this,
>>>>> for example, when looking at performance
>>>>> on different MG levels.
>>>>> Yes, performance on different MG levels is a nice use case. I don't
>>>>> understand how you inject stages into MatMults. To me it's exactly the same
>>>>> problem as with events - you have to define MatMult_custom where you take
>>>>> the original mult and wrap into PetscStageLogPush/Pop and then use
>>>>> MatSetOperation to redefine MatMult. Or do you mean something more elegant?
>>>> You could do that, but usually I think of stages as being structural. I
>>>> think for your example I would push/pop the stage
>>>> inside your Mat operation wrapper (I don't see why you need another
>>>> one), and this behavior could be controlled with
>>>> another option so you could turn it off.
>>>> I meant hierarchies of typically Mats or PCs, where you don't define
>>>> any custom operations but compose together existing types (which should be
>>>> promoted I believe). So no "my" wrapper. As I wrote below:
>>>> Think e.g. of having additive MATCOMPOSITE wrapping multiplicative
>>>>> MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ. You want to measure
>>>>> this MATAIJ instance's MatMult separately but you surely don't want to
>>>>> rewrite implementation of MatMult_Transpose or force yourself to use
>>>>> MATSHELL just to hang the events on MatMult*.
>>> Its not enough to make separate stages for additive MC, multiplicative
>>> MC, and MT? If you want stages for every single
>>> combination created dynamically, you can push another stage when each of
>>> these combinations is created using GetTag()
>>> or something like that. You could switch between these behaviors with an
>>> option.
>>> I'm not sure I understand. Do you mean registering and pushing/popping
>>> these stages in the user's code? You can surely call PetscStageLogRegister
>>> somewhere after PetscInitialize, but where do you place your
>>> PetscStageLogPush/Pop calls?
>> No. You would create a stage when the MATCOMPOSITE is created (or once
>> when any MATCOMPOSITE is created), and push/pop
>> on application.
>> There's surely no problem with creating that stage. But still I don't see
>> how can you push/pop on specific MatMult if it's aggregated together with
>> another MatMults in a higher level MatMult without redefining the latter?
>> And there can be arbitrary number of such levels. If you push/pop your
>> stage in the code calling the top-level MatMult, you can't distinguish
>> different MatMults occurring inside.
> I do not understand what you mean. Each operation would happen in a
> separate stage. Its time for a specific, simple example
> where you think this would break. This could be coded in 10 minutes.
> OK, now I got you. But I didn't mean creating a bunch of tests for any
> possible hierarchy and running them just to get the separated time. I hoped
> that any hierarchy specifiable just from options could be flexibly
> reflected in log view without any coding, additionally with realistic times
> and counts.
> I see a lot of possible benefits. Within PETSc, it's not that obvious with
> MatMult but think of PCSetUp, PCApply, KSPSetUp, KSPSolve. Think of your
> talk's slide-wide example of composed KSPs and PCs specified just from
> options. Don't you really think it would be nice to be able to get
> separated counts, times, flops, MPI messages and so on per user-specified
> stages flexibly?
> In my opinion, flexibility of the log view lags behind the flexibility of
> always advertised composable solvers. With my proposal, you would get it
> just by specifying -log_view_by_prefix.
Yes, but I do not think Events are the right vehicle for this. Solves are
properly thought of as collections of operations. This is the canonical
use case motivating stages. I think an option to push a stage for every
KSP/SNES/TS solve based on prefix would be great.
I do not quite understand the point about active stages. Certainly time is
cumulative across nested stages.
Matt
> And I don't understand what's in this context the advantage of using
>> stages (which are typically registered by user and from his perspective
>> they are generally spanning multiple different operations/function calls)
>> against events which are precisely meant for single operations/function
>> calls (at least I hope so based on thousands of use cases in PETSc itself).
> Events are semantically associated with given operations. Stages are
> semantically associated with the context of an operation.
> So defining a bunch of events for MatMult does not make sense to me,
> whereas defining a bunch of stages for different MatMults
> definitely does.
>> You want me to create a stage which is shorter than then the wrapping
>> event which is I think much uglier than what I propose :-)
> I don't. I think it follows exactly the toplevel design.
> OK, I really don't like it but don't want to argue about aesthetics. But a
> hard argument can be e.g. that only one stage can be active at a time
> (hence Push/Pop name) so what I wanted to have is simply not doable your
> way. From this reason there's probably no hard-wired stage anywhere in
> PETSc.
> Vaclav
> Thanks,
> Matt
>> Vaclav
>> Matt
>>> Thanks
>>> Vaclav
>>> The reason I think this is preferable is that we do not mess with any
>>> logging infrastructure, we just use stages inside of other objects.
>>> Thanks,
>>> Matt
>>>> Thanks
>>>> Vaclav
>>>> Matt
>>>>> Thanks
>>>>> Vaclav
>>>>> 29. 6. 2018 v 22:42, Smith, Barry F. <bsmith at mcs.anl.gov>:
>>>>> On Jun 29, 2018, at 9:33 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>>>>> wrote:
>>>>> 22. 6. 2018 v 17:47, Smith, Barry F. <bsmith at mcs.anl.gov>:
>>>>> On Jun 22, 2018, at 5:43 AM, Pierre Jolivet <
>>>>> pierre.jolivet at enseeiht.fr> wrote:
>>>>> Hello,
>>>>> I’m solving a system using a MATSHELL and PCGAMG.
>>>>> The MPIAIJ Mat I’m giving to GAMG has a specific structure (inherited
>>>>> from the MATSHELL) I’d like to exploit during the solution phase when the
>>>>> smoother on the finest level is doing MatMults.
>>>>> Is there some way to:
>>>>> 1) decouple in -log_view the time spent in the MATSHELL MatMult and in
>>>>> the smoothers MatMult
>>>>> You can register a new event and then inside your MATSHELL MatMult()
>>>>> call PetscLogEventBegin/End on your new event.
>>>>> Note that the MatMult() like will still contain the time for your
>>>>> MatShell mult so you will need to subtract it off to get the time for your
>>>>> non-shell matmults.
>>>>> In PERMON, we sometimes have quite complicated hierarchy of wrapped
>>>>> matrices and want to measure MatMult{,Transpose,Add,TransposeAdd}
>>>>> separately for particular ones. Think e.g. of having additive MATCOMPOSITE
>>>>> wrapping multiplicative MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ.
>>>>> You want to measure this MATAIJ instance's MatMult separately but you
>>>>> surely don't want to rewrite implementation of MatMult_Transpose or force
>>>>> yourself to use MATSHELL just to hang the events on MatMult*.
>>>>> We had a special wrapper type just adding some prefix to the events
>>>>> for the given object but this is not nice. What about adding a
>>>>> functionality to PetscLogEventBegin/End that would distinguish based on the
>>>>> first PetscObject's name or option prefix? Of course optionally not to
>>>>> break guys relying on current behavior - e.g. under something like
>>>>> -log_view_by_name. To me it's quite an elegant solution working for any
>>>>> PetscObject and any event.
>>>>> that possible?
>>>>> possible.
>>>>> Barry
>>>>> I can do that if I get some upvotes.
>>>>> Vaclav
>>>>> 2) hardwire a specific MatMult implementation for the smoother on the
>>>>> finest level
>>>>> In the latest release you do MatSetOperation() to override the normal
>>>>> matrix vector product with anything else you want.
>>>>> Thanks in advance,
>>>>> Pierre
>>>>> PS : here is what I have right now,
>>>>> MatMult 118 1.0 1.0740e+02 1.6 1.04e+13 1.6 1.7e+06
>>>>> 6.1e+05 0.0e+00 47100 90 98 0 47100 90 98 0 81953703
>>>>> PCSetUp 2 1.0 8.6513e+00 1.0 1.01e+09 1.7 2.6e+05
>>>>> 4.0e+05 1.8e+02 5 0 14 10 66 5 0 14 10 68 94598
>>>>> PCApply 14 1.0 8.0373e+01 1.1 9.06e+12 1.6 1.3e+06
>>>>> 6.0e+05 2.1e+01 45 87 72 78 8 45 87 72 78 8 95365211 // I’m guessing a
>>>>> lot of time here is being wasted in doing inefficient MatMults on the
>>>>> finest level but this is only speculation
>>>>> Same code with -pc_type none -ksp_max_it 13,
>>>>> MatMult 14 1.0 1.2936e+01 1.7 1.35e+12 1.6 2.0e+05
>>>>> 6.1e+05 0.0e+00 15100 78 93 0 15100 78 93 0 88202079
>>>>> The grid itself is rather simple (two levels, extremely aggressive
>>>>> coarsening),
>>>>> type is MULTIPLICATIVE, levels=2 cycles=v
>>>>> KSP Object: (mg_coarse_) 1024 MPI processes
>>>>> linear system matrix = precond matrix:
>>>>> Mat Object: 1024 MPI processes
>>>>> type: mpiaij
>>>>> rows=775, cols=775
>>>>> total: nonzeros=1793, allocated nonzeros=1793
>>>>> linear system matrix followed by preconditioner matrix:
>>>>> type: shell
>>>>> rows=1369307136, cols=1369307136
>>>>> type: mpiaij
>>>>> total: nonzeros=19896719360, allocated nonzeros=19896719360
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180702/826d8a35/attachment-0001.html>
