[petsc-dev] GAMG and custom MatMults in smoothers
Stefano Zampini stefano.zampini at gmail.com
Mon Jul 2 08:20:01 CDT 2018
2018-07-02 11:48 GMT+03:00 Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>:
> Barry wrote:
>   This could get ugly real fast, for example, for vector operations, there
> may be dozens of named vectors and each one gets its own logging? You'd
> have to make sure that only the objects you care about get named, is that
> possible?
>    I don't know if there is a good solution within the PETSc logging
> infrastructure to get what you want but maybe what you propose is the best
> possible.
> As I suggest, this behavior would be only triggered by a specific option.
> I think there are actually 4 strings which could be used as an event name
> suffix in log view:
> 1) name
> 2) prefix
> 3) type
> 4) custom string (set by something like PetscObjectSetLogViewSuffix)
> I think the best would be to let user choose by offering
> -log_view_by_{name,prefix,type,suffix}.
> For example, with -log_view_by_prefix, you could readily distinguish
> PCTelescope outer and inner apply, because you would see a separate
> "PCApply (telescope_)" event.
> With -log_view_by_type, you would see PCApply (telescope).
> I think this would be useful because the current class-wide events like
> MatMult or PCApply aggregate very different operations from which some are
> for free and some form hotspots.
> Stefano wrote:
> The issue with this sort of “dynamic” logging is that now PETSc requires
> PetscLogEvent created during the registration of the class, so that all the
> ranks in PETSC_COMM_WORLD have the same events registered.
> What you propose is not generally supported for this specific reason.
> Your “log_name” may work if users register their own classes (with their
> own LogEvents created properly), and currently we don’t have support (maybe
> I’m wrong) to add an “InitializePackage” method for the users’ registered
> classes.
> I don't agree. What I suggest is basically an ability to allow
> automatically created object-wise events, so it _can't_ be managed during
> the class registration. In presence of respective option, the event would
> be created during PetscLogEventBegin by taking the class-wide event's name,
> concatenating the suffix and registering a new event. The event id would be
> stored in the PetscObject structure.
As I said before, now PETSc event model assumes the events are created at
class registration. I'm not saying your dynamic thing cannot be done; I'm
saying it will likely deadlock
> Matt wrote:
> As people have pointed out, this would not work well for Events. However,
> this is exactly what stages are for.
> Use separate stages for the different types of MatMult. I did this, for
> example, when looking at performance
> on different MG levels.
> Yes, performance on different MG levels is a nice use case. I don't
> understand how you inject stages into MatMults. To me it's exactly the same
> problem as with events - you have to define MatMult_custom where you take
> the original mult and wrap into PetscStageLogPush/Pop and then use
> MatSetOperation to redefine MatMult. Or do you mean something more elegant?
> Thanks
> Vaclav
> 29. 6. 2018 v 22:42, Smith, Barry F. <bsmith at mcs.anl.gov>:
> On Jun 29, 2018, at 9:33 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
> wrote:
> 22. 6. 2018 v 17:47, Smith, Barry F. <bsmith at mcs.anl.gov>:
> On Jun 22, 2018, at 5:43 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
> Hello,
> I’m solving a system using a MATSHELL and PCGAMG.
> The MPIAIJ Mat I’m giving to GAMG has a specific structure (inherited from
> the MATSHELL) I’d like to exploit during the solution phase when the
> smoother on the finest level is doing MatMults.
> Is there some way to:
> 1) decouple in -log_view the time spent in the MATSHELL MatMult and in the
> smoothers MatMult
> You can register a new event and then inside your MATSHELL MatMult() call
> PetscLogEventBegin/End on your new event.
>  Note that the MatMult() like will still contain the time for your
> MatShell mult so you will need to subtract it off to get the time for your
> non-shell matmults.
> In PERMON, we sometimes have quite complicated hierarchy of wrapped
> matrices and want to measure MatMult{,Transpose,Add,TransposeAdd}
> separately for particular ones. Think e.g. of having additive MATCOMPOSITE
> wrapping multiplicative MATCOMPOSITE wrapping MATTRANSPOSE wrapping MATAIJ.
> You want to measure this MATAIJ instance's MatMult separately but you
> surely don't want to rewrite implementation of MatMult_Transpose or force
> yourself to use MATSHELL just to hang the events on MatMult*.
> We had a special wrapper type just adding some prefix to the events for
> the given object but this is not nice. What about adding a functionality to
> PetscLogEventBegin/End that would distinguish based on the first
> PetscObject's name or option prefix? Of course optionally not to break guys
> relying on current behavior - e.g. under something like -log_view_by_name.
> To me it's quite an elegant solution working for any PetscObject and any
> event.
> possible?
> possible.
>   Barry
> I can do that if I get some upvotes.
> Vaclav
> 2) hardwire a specific MatMult implementation for the smoother on the
> finest level
> In the latest release you do MatSetOperation() to override the normal
> matrix vector product with anything else you want.
> Thanks in advance,
> Pierre
> PS : here is what I have right now,
> MatMult              118 1.0 1.0740e+02 1.6 1.04e+13 1.6 1.7e+06 6.1e+05
> 0.0e+00 47100 90 98  0 47100 90 98  0 81953703
> PCSetUp                2 1.0 8.6513e+00 1.0 1.01e+09 1.7 2.6e+05 4.0e+05
> 1.8e+02  5  0 14 10 66   5  0 14 10 68 94598
> PCApply               14 1.0 8.0373e+01 1.1 9.06e+12 1.6 1.3e+06 6.0e+05
> 2.1e+01 45 87 72 78  8 45 87 72 78  8 95365211 // I’m guessing a lot of
> time here is being wasted in doing inefficient MatMults on the finest level
> but this is only speculation
> Same code with -pc_type none -ksp_max_it 13,
> MatMult               14 1.0 1.2936e+01 1.7 1.35e+12 1.6 2.0e+05 6.1e+05
> 0.0e+00 15100 78 93  0 15100 78 93  0 88202079
> The grid itself is rather simple (two levels, extremely aggressive
> coarsening),
> type is MULTIPLICATIVE, levels=2 cycles=v
> KSP Object: (mg_coarse_) 1024 MPI processes
> linear system matrix = precond matrix:
>   Mat Object: 1024 MPI processes
>     type: mpiaij
>     rows=775, cols=775
>     total: nonzeros=1793, allocated nonzeros=1793
> linear system matrix followed by preconditioner matrix:
> type: shell
> rows=1369307136, cols=1369307136
> type: mpiaij
> total: nonzeros=19896719360, allocated nonzeros=19896719360
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180702/e1f83b11/attachment.html>
