[petsc-dev] building with MKL
    Matthew Knepley
    knepley at gmail.com
    Sun Jul  1 23:13:56 CDT 2018
On Sun, Jul 1, 2018 at 9:49 PM Jeff Hammond <jeff.science at gmail.com> wrote:
> On Sun, Jul 1, 2018 at 10:43 AM Victor Eijkhout <eijkhout at tacc.utexas.edu>
> wrote:
>> On Jul 1, 2018, at 12:30 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
>> If you really want to do this, then replace COMMON with CORE to
>> specialize for SKX. There’s not point to using COMMON if you’ve got the MIC
>> path already.
>> We advocate CORE on our userguides, but the Intel compiler crashes
>> reliably with that in certain cases. I think in particular Intel has never
>> figured out how complex numbers work.
> Is PETSc using C99 _Complex or C++ std::complex?
It can be configured to use either.
  Matt
> I haven’t heard any complaints about how Intel compilers treat
> ISO-standard complex types. I’ll see what’s in the ticket system now.
> If the compiler crashes it’s always on the petsc complex mode. I think I
>> have submitted tickets about that, so maybe it’s fixed in update 3.
> Version 17 I assume?
>> I have also seen cases where CORE gives numerical problems and replacing
>> by COMMON fixed them. Sorry, that was a user ticket and having solved it I
>> didn’t bother to submit an Intel support ticket.
> AVX-512DQ shouldn’t change numerical results so this is an indirect effect
> and worthy of creating a compiler bug report if you can isolate the issue.
>> The support website is a nightmare anyway, so I’m not overly motivated to
>> submit support tickets in the first place.
> I know that website sucks, but I have filed 50+ bug reports that way in
> the past 4+ years, because it is the single most effective way to get
> positive results.
> If you send me single-file preprocessed (Linux preferred, but Mac works)
> MCVEs, I’ll put them straight into the internal ticket system.
> Jeff
> Jeff Hammond
> http://jeffhammond.github.io/
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180701/8674b6c5/attachment-0001.html>
