[petsc-dev] Adding p4est to nightly tests
Lisandro Dalcin dalcinl at gmail.com
Sun Jul 1 05:15:04 CDT 2018
And what about adding pragmatic? Right now I'm getting this failure in master.
make -f gmakefile test search=snes_tutorials-ex12_mg_newton_coarse_2
Use "/usr/bin/gmake V=1" to see verbose compile lines, "/usr/bin/gmake
V=0" to suppress.
          CC arch-packages/tests/snes/examples/tutorials/ex12.o
     CLINKER arch-packages/tests/snes/examples/tutorials/ex12
        TEST arch-packages/tests/counts/snes_tutorials-ex12_mg_newton_coarse_2.counts
not ok snes_tutorials-ex12_mg_newton_coarse_2
# [0]PETSC ERROR: --------------------- Error Message
# [0]PETSC ERROR: Petsc has generated inconsistent data
# [0]PETSC ERROR: Coarse dof 230 maps to both 79 and 674
# [0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
# [0]PETSC ERROR: Petsc Development GIT revision:
v3.9.2-825-g3a11c7608d  GIT Date: 2018-07-01 06:15:09 +0200
# [0]PETSC ERROR: ../ex12 on a arch-packages named kw14821 by dalcinl
Sun Jul  1 12:54:44 2018
# [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-packages
--download-chaco --download-ctetgen --download-eigen
--download-exodusii --download-hdf5 --download-metis --download-netcdf
--download-p4est --download-parmetis --download-pnetcdf
--download-pragmatic --download-ptscotch --download-triangle
--download-yaml --with-gmp --with-mpfr
# [0]PETSC ERROR: #1 DMPlexComputeInjectorFEM() line 2297 in
/home/devel/petsc/dev/src/dm/impls/plex/plexfem.c
# [0]PETSC ERROR: #2 DMCreateInjection_Plex() line 6664 in
/home/devel/petsc/dev/src/dm/impls/plex/plex.c
# [0]PETSC ERROR: #3 DMCreateInjection() line 1169 in
/home/devel/petsc/dev/src/dm/interface/dm.c
# [0]PETSC ERROR: #4 PCSetUp_MG() line 691 in
/home/devel/petsc/dev/src/ksp/pc/impls/mg/mg.c
# [0]PETSC ERROR: #5 PCSetUp() line 932 in
/home/devel/petsc/dev/src/ksp/pc/interface/precon.c
# [0]PETSC ERROR: #6 KSPSetUp() line 381 in
/home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c
# [0]PETSC ERROR: #7 KSPSolve() line 612 in
# [0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in
/home/devel/petsc/dev/src/snes/impls/ls/ls.c
# [0]PETSC ERROR: #9 SNESSolve() line 4350 in
/home/devel/petsc/dev/src/snes/interface/snes.c
# [0]PETSC ERROR: #10 main() line 1065 in
/home/devel/petsc/dev/src/snes/examples/tutorials/ex12.c
# [0]PETSC ERROR: PETSc Option Table entries:
# [0]PETSC ERROR: -dm_coarsen_hierarchy 5
# [0]PETSC ERROR: -dm_plex_hash_location
# [0]PETSC ERROR: -dm_plex_remesh_bd
# [0]PETSC ERROR: -dm_plex_separate_marker
# [0]PETSC ERROR: -dm_refine 5
# [0]PETSC ERROR: -dm_view
# [0]PETSC ERROR: -interpolate 1
# [0]PETSC ERROR: -ksp_monitor_true_residual
# [0]PETSC ERROR: -ksp_rtol 1.0e-12
# [0]PETSC ERROR: -ksp_type richardson
# [0]PETSC ERROR: -ksp_view
# [0]PETSC ERROR: -mg_levels_ksp_max_it 2
# [0]PETSC ERROR: -mg_levels_ksp_monitor_true_residual
# [0]PETSC ERROR: -pc_mg_levels 3
# [0]PETSC ERROR: -pc_type mg
# [0]PETSC ERROR: -petscspace_order 1
# [0]PETSC ERROR: -run_type full
# [0]PETSC ERROR: -snes_converged_reason ::ascii_info_detail
# [0]PETSC ERROR: -snes_monitor
# [0]PETSC ERROR: ----------------End of Error Message -------send
entire error message to petsc-maint at mcs.anl.gov----------
# application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
ok snes_tutorials-ex12_mg_newton_coarse_2 # SKIP Command failed so no diff
#   Summary
# FAILED snes_tutorials-ex12_mg_newton_coarse_2
# success 0/1 tests (0.0%)
# failed 1/1 tests (100.0%)
# todo 0/1 tests (0.0%)
# skip 0/1 tests (0.0%)
# Wall clock time for tests: 42 sec
# Approximate CPU time (not incl. build time): 0.0 sec
# To rerun failed tests:
#     /usr/bin/gmake -f gmakefile test
search='snes_tutorials-ex12_mg_newton_coarse_2'
# Timing summary:
#   snes_tutorials-ex12_mg_newton_coarse_2: 0.00 sec
On Sun, 1 Jul 2018 at 01:07, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> Satish,
> when you have time can you add p4est to some of the archs we tests nightly?
> Matt and/or Toby, is there any reason why p4est is not under the testsuite?
> Thanks,
> Stefano
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
