[petsc-dev] Missing typedef ?
    Franck Houssen
    franck.houssen at inria.fr
    Mon Jan 29 04:28:32 CST 2018
I confirm this is now OK at my side on master. Thanks.
Franck
----- Mail original -----
> De: "Barry F. Smith" <bsmith at mcs.anl.gov>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "petsc-dev" <petsc-dev at mcs.anl.gov>
> Envoyé: Dimanche 28 Janvier 2018 18:34:21
> Objet: Re: [petsc-dev] Missing typedef ?
> > On Jan 28, 2018, at 10:50 AM, Franck Houssen <franck.houssen at inria.fr>
> > wrote:
> > Hello,
> > In petscmat.h, the line "#define MatSolverPackage char*" shouldn't it be
> > replaced with "typedef char* MatSolverPackage" ? (like it's done for
> > MatType and others)
>   You are correct.
> > When trying to use MatSolverPackage from a cpp file where "petsc.h" and
> > "petscmat.h" have been included I get this error : error:
> > ‘MatSolverPackage’ does not name a type; did you mean ‘MatSolverType’?.
> > Looks like this error does occur, or not, depending on compiler / OS : this
> > is OK with debian but not with ubuntu-trusty (line 2191 here
> > https://travis-ci.org/fghoussen/geneo4PETSc/jobs/334384582).
> > I would say the compile error can occur, or not, according to what
> > -fvisibility defaults to.
>    Unfortunately I cannot make the fix in maint because it will cause a large
>    number of conflicts with master (I tried) so I can only do the fix in
>    master and as Jose notes also in master it is now MatSolverType.
>    Thanks for reporting the issue,
>    Barry
> > Not sure of this...
> > Franck
