[petsc-dev] transition to GitHub
    Sean Farley
    sean at farley.io
    Sun Jan 28 14:33:24 CST 2018
Smith, Barry F. <bsmith at mcs.anl.gov> writes:
>    Jed (and others)
>       What do you recommend as the least painful way to move the PETSc repository and all its issues, etc over to GitHub?
>      Thanks
>         Barry
> One more time of dealing with Bitbucket's cumbersome way to merge/update other users pull requests into PETSc and I think it will be time.
I'm a bit behind on email so I missed this initially. FWIW, we have
plans to implement a different model but as with everything bureaucratic
it's been a lower priority than implementing GDPR. I agree that missing
PR refs is one of the biggest sore points on Bitbucket.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180128/cb2002df/attachment.sig>
