[petsc-dev] transition to GitHub
Lawrence Mitchell
wencel at gmail.com
Mon Jan 15 10:00:02 CST 2018
Barry,
Jed (?) already maintains mirrors of the main petsc repos on github at:
https://github.com/petsc
So step one would be to get access to that organisational account.
It is possible to drive both bitbucket's and github's API to query (and create) issues. So you can script the conversion of issues (including comments).
Here's a python script that does that:
https://github.com/jeffwidman/bitbucket-issue-migration
I have not used it, but reading through the code it doesn't look to do anything monumentally complicated. There appear to be three steps:
1. Figure out the correct bitbucket API url for listing issues (and then grabbing the comments)
2. Do some minimal munging of the issue and comments from bitbucket-approved markdown to github markdown (some of the linking conventions are different).
At this stage, you can optionally map bitbucket to github user names.
3. Post the resulting munged issue to github using their API.
I suppose it would be easy to just run it on a test repo.
I note that migrating live pull requests appears to be much harder (no-one appears to have done the work).
I don't know if you feel like you need that too.
Cheers,
Lawrence
> On 15 Jan 2018, at 14:35, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Jed (and others)
> What do you recommend as the least painful way to move the PETSc repository and all its issues, etc over to GitHub?
> Thanks
> Barry
> One more time of dealing with Bitbucket's cumbersome way to merge/update other users pull requests into PETSc and I think it will be time.
> Probably at first it would just be the one repository and all others stay behind.
