[petsc-dev] Missing typedef ?
    Jose E. Roman
    jroman at dsic.upv.es
    Sun Jan 28 11:14:13 CST 2018
MatSolverPackage has been renamed to MatSolverType in a recent commit in master.
Jose
> El 28 ene 2018, a las 17:50, Franck Houssen <franck.houssen at inria.fr> escribió:
> Hello,
> In petscmat.h, the line "#define MatSolverPackage char*" shouldn't it be replaced with "typedef char* MatSolverPackage" ? (like it's done for MatType and others)
> When trying to use MatSolverPackage from a cpp file where "petsc.h" and "petscmat.h" have been included I get this error : error: ‘MatSolverPackage’ does not name a type; did you mean ‘MatSolverType’?.
> Looks like this error does occur, or not, depending on compiler / OS : this is OK with debian but not with ubuntu-trusty (line 2191 here https://travis-ci.org/fghoussen/geneo4PETSc/jobs/334384582).
> I would say the compile error can occur, or not, according to what -fvisibility defaults to.
> Not sure of this...
> Franck
