[petsc-dev] Possible bug in PCFIELDSPLIT
    Lisandro Dalcin
    dalcinl at gmail.com
    Wed Jan 10 10:41:24 CST 2018
On 10 January 2018 at 18:43, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>    Are you pointing out there is a missing atype == in the inner check and it should be
>> atype ==
>> MAT_SCHUR_COMPLEMENT_AINV_DIAG ? "" :
>> (atype == MAT_SCHUR_COMPLEMENT_AINV_BLOCK_DIAG ? "block " : "lumped
I don't know :-) I got the warning from a build using GCC 7.2 while
working on something else, and the code snippet pointed by the
compiler looks really suspicious to me, so I posted it here before I
forget about it. I guess your diagnostic is correct, the code is just
missing the inner "atype ==" part you wrote.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
