[petsc-dev] How is PETSC_FLIB generated in BuildSystem?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Mon Jan  8 11:25:58 CST 2018
   Blaise,
     I think you need to copy over the generateliblist() method and have it provide the different libraries depending on whatever you need to have it depend on.  Note that if need be you can have no libelist and haver your generateliblist do all the work of generating the library list. Note you also need to handle the case with no Fortran compiler and hence does not include the fortran libraries.
    God luck.
   Barry
> On Jan 8, 2018, at 11:03 AM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> I can’t figure out how is the library list in $PETSC_FLIB generated. How would I need to modify exodusii.py in order to add the proper library (libexodus_for with 64bit int and libexoIIv2for32 with 32 bit int)?
> Regards,
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
