[petsc-dev] How is PETSC_FLIB generated in BuildSystem?
    Blaise A Bourdin
    bourdin at lsu.edu
    Mon Jan  8 11:03:15 CST 2018
I can’t figure out how is the library list in $PETSC_FLIB generated. How would I need to modify exodusii.py in order to add the proper library (libexodus_for with 64bit int and libexoIIv2for32 with 32 bit int)?
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
