[petsc-dev] [Mike McQuaid] Re: [Homebrew/homebrew-core] PETSc: import from homebrew-science (#23598)
Smith, Barry F. bsmith at mcs.anl.gov
Mon Feb 26 13:04:36 CST 2018
> On Feb 25, 2018, at 10:07 PM, Jed Brown <jed at jedbrown.org> wrote:
> "Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>>>> On Feb 25, 2018, at 9:46 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>> Satish Balay <balay at mcs.anl.gov> writes:
>>>>>> On Sun, 25 Feb 2018, Lawrence Mitchell wrote:
>>>>>>>> On 25 Feb 2018, at 21:13, Jed Brown <jed at jedbrown.org> wrote:
>>>>>>>> The try part of that commit (around os.remove) is necessary.  Also,
>>>>>>>> "rmdir -p" provides a useful semantic in this context, but needs to be
>>>>>>>> implemented manually in Python (or I don't know where that functionality
>>>>>>>> is available in the standard library).
>>>>>>> shutil.rmtree
>>>>>> I think [in uninstall script] - we want to delete dirs only if the dir
>>>>>> is empty.  [if not empty - it could contain files installed by a
>>>>>> different package - as its common to install multiple packages in the
>>>>>> same prefix]
>>>>> Yeah, "rm -r" is much different from "rmdir -p".
>>>>>> Also - thinking about it - its not clear if we can really do a proper
>>>>>> uninstall - esp with --download-packages.
>>>>>> Previously - 'make install' would also install the downloaded packages
>>>>>> and we kept track of them for the uninstall script. But now - we let
>>>>>> each package do its own 'make install' to the prefix location. But we
>>>>>> don't have an 'uninstall' option for these externalpackages. [I don't
>>>>>> know if any of them provide 'make uninstall' feature]
>>>>> PETSc --download-* is a package manager, albeit very crufty (though it
>>>>> gets the job done).  Basically all package managers function by
>>>>> installing with a private DESTDIR, bundling up the result, then
>>>>> unpacking into the target.
>>>>  That's not how PETSc's works. It tells the each package the final prefix and each package installs into that location directly.
>>> That's just because PETSc's package manager is kinda crappy because
>>> nobody wants to admit that it really is a package manager.  If uninstall
>>> is to be a thing at all, then it's definitely the way to go.
>>   We use to do it the "package manager way" but I think so many packages couldn't be DESTDIRed and then installed that we went with the install directly approach.
> Many/all of those packages are available in Debian or Conda or Homebrew, etc.
>>   I think it is wrong to call PETSc's thing a package manager. It is and always has been only a package installer, it is hopeless at managing packages.
> And yet we're talking about uninstall and we also have support for
> upgrading them (except that it doesn't clean up the old version and thus
> isn't very reliable).
   Huh, it has support for upgrading them?
>  It's a package manager despite conspicuous
> missing features.
